Results 1 to 2 of 2
Thread: egr / throttle body clean at 45K
    Sodding Typical on Sea
    Default egr / throttle body clean at 45K
    My car is on 45K, and I suspect the previous owner (to 34.6K) didn't really do many long trips to keep the system clean. I however tend to do a mix of 200>500 mile round trips in a day and commutes,so today, I stripped the throttle body and egr off and was stunned at how clean the egr was!
    it had about a 1mm thick coating of hard compacted soot, very little loose flaky debris, the solenoid moves very freely and the entire unit was in good shape.
    The throttle body had some thick sludgy paste type oil on the butterfly and around the hinge points.
    The inlet manifold had similarly very little crud around the air flutes from the egr to the throttle within the manifold itself so I scooped what was there out wiped it all over and rebuilt it.
    there was nothing to see in the pics as the post on how to remove is as detailed and shows far more than anything I observed.
    OK I rebuilt everything, and the idle seems a bit smoother and the throttle a bit sharper but this is probably all in my imagination if you get my drift?
    VIP-Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Job well done there Derek
    After getting my hands dirty yesterday cleaning out the EGR, I think I might have a go at whipping the throttle body off. Especially after seeing a few of the pics on here and how gunged up they can get.
    Hoping mine won't be too sludged up, just need to get to VX and get a replacement gasket first before I start anything.
    Not sure if the 120 has a similar T/B to the 150 but if it does I'll be checking to see if the electronics (solder joints) are tickety-boo as I have noticed the occasional judder but we shall see.
    Anyway glad you saw some improvement
    Damo
    Already replaced:-
    Alternator,
    Drilled/Grooved Discs & Pads, Eibach Springs, EGR Valve, 50W HID's 6000k, K&N Panel Filter, LED footwell & boot lights
  1. Clean throttle. Body
    By daddy5times in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2013, 20:17
  2. How to clean the throttle body of CDTi 1.9?
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2011, 13:03
  3. 2.2 dti clean throttle body
    By tomo610 in forum Engine & Drivetrain
    Last Post: 3rd October 2010, 13:36
  4. DTI Throttle Body Clean
    By si_hoss in forum Engine & Drivetrain
    Last Post: 7th July 2010, 13:37
