Thread: Towing 1.8 vvti
    Oct 2007
    Ripon
    Default Towing 1.8 vvti
    Does anyone tow in the 1.8 VVTi? Looking at a 2 berth caravan.
    Pretty much run of the mill with no weight so what are the odds at moving along?
    Mar 2011
    S
    Dont think you would be moving along to quickly! Ive got the 1.8vvt and dont think i would like a caravan on the back.
    May 2011
    bispham, blackpool
    Quote Originally Posted by robdd1 View Post
    we towed a caravan years ago in a 1.8 vectra b it towed it fine but after the 3rd time of staying local we tried taking it further and it didnt cope to well going up hills we had to work the gears got us to rhyl from blackpool but on way home cambelt snapped just couldnt take strain
    something good came out of it as we bought a v6 sri vectra b after that and we towed that caravan around the country and since then we always go for the big engine cars
    Oct 2007
    Ripon
    Cheers for the input.
    Pretty much confirmed what I was thinking.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    It will tow just fine, ok its not going to rip a hole in the tarmac. My dad has towed caravans the length and breadth of this country in cars from a 1.3 Avenger Estate, 1.6 Cortina's a 2.3D Sierra which had a whole 68bhp!!!! He's towed caravans up and over Sutton Bank, in Yorkshire, using the cortina's and the sierra and back then caravans had full steel chassis' and not the lightweight chassis of todays 'van's.
    May 2011
    bispham, blackpool
    they dont build them like that anymore
    in the past ive had mk2 escorts and sierras and never once had any engine troubles and i was a teenager then went everywhere flat out the only problems was rust they were the days
    when you drive around a campsite look at all the cars most are v6s and diesel oil burners cars or 4x4 this should tell you the best engine for the job you dont see many caravaners in a 1.8 this is the main reason why i buy v6 engine cars as i use to tow caravans
    and have suffered by it using a 1.8
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    It all depends on how much the 2 berth van that you are intending to buy weighs tbh.
    My last 2 berth van (ABI marauder) was 950kg max weight but my new one (Swift Corniche) is 1250kg
    The swift has all the toys fitted and is longer hence the increased weight.
    You will have to work the gears as i've not towed with a petrol that you've not had use the gears yet. Diesels have alot of torque meaning hills are easy work for them.
    Best bit about caravanning is there is no hurry, if your in a hurry then your defeating the point of a caravan holiday
    If you're just starting out don't buy a big expensive new van. You may not enjoy it, you may misjudge when towing and damage it etc. When your experience has increased and you've decided you enjoy it you can then buy a newer and better van.
  1. What is meant by 1.8 VVTI? is the vvti engine better or worse?
    By Deann in forum Vectra C / Signum Car Chat
    Last Post: 14th May 2011, 11:19
  2. 1.8 VVTi MPG
    By shan in forum Vectra C / Signum Car Chat
    Last Post: 3rd June 2010, 11:33
  3. 1.8 VVTi LPG
    By ShauneDTi in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2010, 11:30
  4. 1.8 vvti sri - mpg
    By gangleyshag in forum Vectra C / Signum Car Chat
    Last Post: 31st October 2009, 11:30
  5. 1.8 vvti or not
    By surreyl31 in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2007, 23:30
18vvTi. Tow
Insignia 1.8 vvt towing
