Thread: egr 1.9 16v
    luton
    Default egr 1.9 16v
    Hi I'm trying to find the how to, for cleaning the egr valve, can some one point me in the right direction
    Aug 2010
    Derbyshire
    Quote Originally Posted by gdansk View Post
    This is it http://www.vectra-c.com/forum/showthread.php?t=45867 just click on the picture links.
    Any other info just ask, done mine recently but I didn't strip the solenoid/spring mine was ok.
    The rest of it was clogged with black soot. You may want to get a gasket set before starting. These are readily available on ebay for around £5.
    Mick
    Regular Member Mr Hyde's Avatar
    Feb 2011
    Suffolk
    On a further note guys, a quick Q for those that have done this...
    How regular is this recommended? Mine is sitting at 55k now, is it worth me doing it and would I notice anything? Ta
    Sodding Typical on Sea
    Just did a clean down of mine here:-
    http://www.vectra-c.com/forum/showth...28#post1579428
    VIP-Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Decided to strip and clean my old EGR valve yesterday.
    I had to replace it with a new one in November last year as I was getting the P0400 fault code.
    So thought might as well overhaul this one and save it as a spare for when I come to clean out the new one then swap them over
    On the valve side I cleaned all the carbon and crud out using a mix of petrol and gunk
    The solenoid side was seized solid.
    Attachment 44466
    So using the HOW-TO that jon7278 did (pdf format one attached below), I drilled the solenoid casing as directed and knocked out the inners. Took quite a bit of persuading to come out but persevered and after a few whacks with the lump hammer I finally had it all apart.
    (Point to note:- make sure you don't lose the spring as they do ping out)
    I sanded the middle bushing using P800 emery paper and did the same for the solenoid housing. I then put it all back together.
    The pin slides up and down perfectly now
    Tried to take a video of it but it didn’t come out too well, needed at least 3 hands and only had the crappy iphone to hand.
    I have uploaded the vids to photobucket so you are welcome to view them and compare the action of your EGR (again sorry about the quality)
    http://s226.photobucket.com/albums/d...pedCleaned.mp4
    http://s226.photobucket.com/albums/d...heSolenoid.mp4
    Anyway, hope it helps
    Damo
    Already replaced:-
    Alternator,
    Drilled/Grooved Discs & Pads, Eibach Springs, EGR Valve, 50W HID's 6000k, K&N Panel Filter, LED footwell & boot lights
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    I do mine every 3 months or there abouts, Its a quick job & well worth the effort.
    Jul 2011
    Birmingham
    Has anyone got a picture of the engine bay as a whole identifying the EGR? I'm 99% sure mines not got one fitted, but I'm 50% sure I'm looking in the wrong place!!
    Thanks!
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    I don't waste time with it. Had two on the car and they were problematic, so mine is now blanked. No fuss, no crap in the inlet manifold and engine is smoother.
    If the EGR valve is working fine, great, but I think keeping it clean is a waste, it's an item which shouldn't need to be cleaned anymore frequently than a year.
    The design of it is poor and soot is allowed back into the sleeve and into the spring and solenoid areas of the valve actuator. The guide - which is a good one - details the shaft in the EGR valve which corrodes and causes the apparent sticking. The same effect is also by soot which manages to get trapped in the valve sleeve inside the housing. Either way both are a pain and both demand work - which I think is something owners shouldn't need to carry out - especially if you're going out to it ever 6 months. In that case blank it off imo. If the blanking takes your fancy have a read here:
    http://www.vectra-c.com/forum/showthread.php?t=131610
    I gave up with mine - a long while off.
    Insignia VX-Line Nav CDTI 170.
