Results 1 to 10 of 27
Thread: Traction Control
    Jul 2011
    UK
    Default Traction Control
    Bit of a silly question I know but does my Sri have TC? it is a 2005 model. I cant get a definitive answer anywhere.
    Regular Member simplesi's Avatar
    Aug 2009
    probably off taking photos
    Vehicle : 1.9 cdti 150
    Trim : elite
    mine is a 2.2 direct sri on an 05 plate and has tc HTH
    Full Member Big Sig's Avatar
    Very easy to find out, spin the wheels and see if you get a yellow flashing symbol on the dash.
    (awaits switch related question)
    if you wheel spin the car in snow/ rain does a flashing light show up on the dash ( its a pic of a car with 2 curvd car lines behind it)
    if it does you have t/c
    also if you check the abs pump it will have a sticker on there saying if you have t/c , or esp
    beat me too it sean
    Oct 2006
    Waterloo, Liverpool
    12 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Quote Originally Posted by marktaylor View Post
    beat me too it sean
    Also if the ESP/TC 'wavy line/car' icon' appears on the dash (before going out) when you turn on the ignition (part of startup diagnostics), then you have TC, if it doesn't , you don't.
    Jul 2011
    UK
    Will look. Never thought of that, only had the car 6 days. Mind you my other car, a Zafira A 2.0DTI has it, but my mondeo I got rid of last week didnt.
    EDIT just looked - The Zafira has the car in the triangle with skid marks symbol with ignition on. The Veccy hasn't. Is there a diagnostic gauge/bulb check (like the mondy had)? I think then I had to hold the trip button in and turn on the ignition and press it to cycle through the functions.
    Could it be the bulb? Or have I just not got TC? Ah well..
    The TC is fitted, by engine specification, as standard to all but the 1.8
    The warning symbol should appear briefly when you commence the start up
    Also, does the ABS warning light briefly appear beside it?
    You should be able to test by simply applying lots of power in first gear
    The TC should retard the fuel, before applying the brakes
    Quote Originally Posted by ijk571 View Post
    Again, depends on engine specification and is similar to the Vectra in that the base engine does not have it
    Equally, I did not find it of use
    Jul 2011
    UK
    The abs light comes on briefly. I'm sure I'll not really need it, but just was curious.
    Regular Member Jezzy's Avatar
    S.E
    PM me your reg number, and I'll see if TC is listed against your car's build spec.
    Regular Member Si-SRI's Avatar
    Oct 2009
    LINCOLNSHIRE
    Sorry to jump in the thread but is their a way of showing what you car came with as standard from the factory like ford etis?
  1. my traction control how to
    By jpbroad1970 in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2012, 20:01
  2. traction control
    By ggg1979 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2009, 18:07
  3. 2.0T Traction Control
    By kryton01 in forum Engine & Drivetrain
    Last Post: 20th October 2009, 17:18
  4. traction control
    By jsnlvxr in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2009, 21:56
  5. traction control
    By jamesv6 in forum Vectra C / Signum Car Chat
    Last Post: 14th August 2006, 00:13
