Results 1 to 10 of 20
Thread: Oil & filter change in 150cdti
    Liverpool
    Default Oil & filter change in 150cdti
    Looking to save myself some £££'s as i have water pump & belt, service & first MOT to pay for soon
    However i always check levels etc, filters are fine (fuel filter replaced less than 10K ago) but i am yet to perform my own oil and filter change
    To save some wonga, i might do it myself, can anyone tell me where the filter is located and also the sump plug. i am fairly confident at diy so dont think it will be an issue
    Also does anyone know the part number for the sump plug washer as i will replace this
    Cheers lads
    Engine : 1.9 CDTi
    The oil filter is at the back of the engine near the bottom. Its a cartridge type that sits in a alloy housing.
    I think its a 32mm spanner/socket you need to undo it.
    Aug 2010
    Derbyshire
    You need one of these http://cgi.ebay.co.uk/32mm-Oil-Filte...item48412d4b77
    Also you need to get the car raised (obviously) enough to get underneath as you need to remove the under tray. There is a service flap on the under tray to get at the sump plug, this swings down but you won't have enough room for this as you can't get the car high enough.
    I raised mine on the offside only, took the under tray off completly and did the job.
    Watch out when you take the filter off as oil goes everywhere (plenty of soak up rags) there is a drain tube on the housing but still messy. Whilst the oil was draining I dropped the car level from the jack to make sure it complety drained.
    I reused my sump plug, no problems.
    Oh and BTW I used an axle stand as well as my jack, safety first if you're going under the car.
    Mick
    Liverpool
    thanks for the advice lads, i think its about time i invested in some axle stands anyway!!
    Regular Member Jezzy's Avatar
    S.E
    If you happen to have the Halfords 150 piece socket set, it comes with a 32mm socket.
    Liverpool
    i have got some huge sockets in the garage from my motocross days, im sure there will be a 32 in there
    north east
    Cut the bottom off a 2lt pop bottle and use it as a funnel when you take the oil filter off ;-)
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Good luck, I bought the parts on Trade Club then got a local mechanic to fit them, he said the oil filter is a real pig as room is very tight.
    Quote Originally Posted by Grumpy1954 View Post
    Your mechanic needs to man up......D
    Aug 2007
    North West
    Trim : SRI With a few added extras
    Engine : 1.9 CDTI 120
    Year : 06
    very much diy-able,I've done both the cdti 150 and the 120, let me know if you want a hand mate, got all the kit in north Liverpool
  1. Oil & Filter Change
    By Cyruskint in forum Y & Z30DT Specific
    Last Post: 16th March 2012, 11:37
  2. Does anyone run a cone filter on 150cdti?
    By paul_sri150 in forum Diesel Engine related
    Last Post: 22nd May 2010, 23:30
  3. oil filter and oil change - 3.2v6
    By effone in forum Engine & Drivetrain
    Last Post: 7th December 2008, 18:07
  4. How much for a oil & filter change
    By willc01 in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2007, 13:31
  5. Oil filter change on a VXR
    By Andyuk911 in forum Engine & Drivetrain
    Last Post: 23rd May 2006, 17:53
