Results 1 to 10 of 11
Thread: cdc, continuos damping control
    sheffield
    Default cdc, continuos damping control
    does anyone know ware the cdc module is located on a 2006 vectra elite 3.0 cdti, mine is not talking to what ever it should be talking too, so want to check that its plugged in correctly, but it would help if i knew ware it was..
    sheffield
    Anyone know....
    Engine : 1.9 CDTi
    Behind the lower instrument panel
    Have you checked the sensors on the strut tops
    sheffield
    Quote Originally Posted by lee gsi View Post
    Thanks but what do you mean by behind the lower instrument panel, yes ive checked all plugs on the suspension legs and they are all pluged in ....
    Engine : 1.9 CDTi
    Pretty sure its behind the big plastic panel under the steering wheel.
    sheffield
    Ok thanks, ill check there
    VIP-Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    According to TIS the CDC control unit is located on the right-hand side on the A-pillar
    You'll need to remove inner panelling, lower instrument panel padding (the big cover under the steering wheel). In order to remove this panel you'll need to remove the light switch. To do this, when switch is in off position, push the knob in & turn to sidelight position. You can then pull the switch out
    Then you should be able to locate the CDC
    Hope it helps
    Already replaced:-
    Alternator,
    Drilled/Grooved Discs & Pads, Eibach Springs, EGR Valve, 50W HID's 6000k, K&N Panel Filter, LED footwell & boot lights
    Engine : 1.9 CDTi
    DAMO isnt that for left hand drive cars?
    VIP-Member sulten's Avatar
    Øvre Årdal, Norway
    Nope on Opel it's on the passenger side, then we remove the glove box.
    Kristian
    68 Diplomat-A 46S
    95 Vectra-A C20NE
    07 Vectra-C Z19DTH
    sheffield
    Quote Originally Posted by Damo77 View Post
    Hope it helps
    Thanks a lot mate..
  1. For Sale: Vectra Light control panel without Front Fog control: Cheap!
    By Envy in forum Parts for sale
    Last Post: 19th April 2012, 00:05
  2. Silentcoat (Like Dynamat!) Sound Damping Mat
    By snapsnap in forum Parts for sale
    Last Post: 1st March 2011, 13:28
  3. Continuous damping fault light
    By rustywheelnut in forum Troubleshooting
    Last Post: 31st March 2010, 18:39
  4. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
  5. Continuous Damping Control (CDC) and TC lights on!
    By Rafeek in forum Electrical & ICE (including SatNav)
    Last Post: 9th April 2007, 21:38
vectra c damping control unit
