Thread: When you're wrong, you're wrong
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Default When you're wrong, you're wrong
    The GT2556V was fitted and tested and made masses of boost, too much really but not until after 3500rpm... Until then it was not worth driving. So I would imagine the rolling road figures would be great if that was what I wanted but to drive it was pointless.
    I'm not one to be detered though and I have many ideas for the next attempt but not this weekend, three turbo changes if enough I think.
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    trial and error is a perfectly good way to test new layouts.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    how much boost did it make
    Engine : 1.9 CDTi
    Need to be twin turboed
    Seems to be the way manufactures are going with SAAB's 2 litre 190 bhp Twin turbo diesel and and Volvos 2.4 twin turbo 205 bhp.
    Then let the tuners loose on them
    FIAT's 1.9 JTD twin turbo Twin stage turbo: http://www.eurocarblog.com/post/499/...th-100-hpliter
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    I don't know what boost it made, the sensor only goes upto 3 bar absolute (43.5psi - atmospheric). The pressure was off the gauge from 3500 to 5500rpm. The first hybrid that I have put back in runs at the limit of the pressure sensor from 2200rpm to 5500rpm. The efficiency of the 52mm compressor is not as good at top end though and the air is heated too much.
    I'm gonna have another look next week after a rest
    spoons
    Guest
    Quote Originally Posted by nutron View Post
    Holy **** 43.5psi... my VXR is at 23-25psi and I thought that was high
    Jun 2011
    Elland
    Quote Originally Posted by spoons View Post
    It is for a petrol Biggest enemy of upping the boost is detonation / knock spoiling your fun.
    Nutty Yanks have done twin sequential turbos on Cummins 5.9 diesels running near 100psi and getting around 1000hp (smoking like a tyre fire at that )
    They're not afraid to break things, though!
    spoons
    Guest
    Quote Originally Posted by hebblemarine View Post
    It is for a petrol Biggest enemy of upping the boost is detonation / knock spoiling your fun.!
    Yeah, my BHP was reined back in to allow for correct fuelling at the higher RPM and safe injector duty cycles.
    I need bigger injectors next to get up to 350 BHP
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    minus atmospheric, which is about 14.5psi (1bar) so north of 29psi. I had readings of upto 32psi on one set of rollers but this was running more pressure than that as I was not getting the oil mist blowing out on the rollers.
    I'm putting a GT2056V combination together on Friday, won't be fitting until next week though.
  1. What's next to go wrong?
    By pswfps in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2011, 22:32
  2. What am i doing wrong??
    By Andy79 in forum Electrical & ICE (including SatNav)
    Last Post: 19th September 2009, 21:30
  3. Wrong place wrong time.
    By silverhairedracer in forum General Chat
    Last Post: 29th October 2008, 14:20
  4. When NOS goes wrong
    By chrisgettings in forum Comedy & Humour
    Last Post: 3rd March 2008, 22:28
