Thread: regen on 1.9 cdti 150 06 sri
    Sep 2010
    west sussex
    Default regen on 1.9 cdti 150 06 sri
    did a regen .....how do i know if it was successful?
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    how do you know you did a regen?
    Regular Member Reevo's Avatar
    Nov 2010
    Leicestershire
    Yeah, i dont know what to look/listen for either, so how do you know?
    Regular Member coooky's Avatar
    May 2011
    washington
    i do one each day sounds like plop plop job done
    sorry i will get my coat
    Oct 2010
    London
    Engine runs lumpy when it is running regen , very noticeable when trundling along in first with no throttle.
    Fuel usage goes up too, using 1gal/hr at idle and sitting in the low twenties when driving.
    Can sometimes put out a lot of heat too!
    Jun 2011
    Elland
    Quote Originally Posted by Homer View Post
    You won't 'know' whether the regen was 'successful' unless you have software to investigate the % filter stauration before and after. Don't worry about it! Do let it complete a regen, though. Even if it means sitting with the engine running for 5 mins or so after the end of a journey. You will know the process is finished when idle fuel consumption drops back from 1gal to 0.2 (ish) and the engine note changes.
    Sep 2010
    west sussex
    Thumbs up
    Quote Originally Posted by hebblemarine View Post
    ok..thanks for advice
    Jun 2011
    Elland
    No problem!
    According to the AA / RAC premature DPF failure is mostly down to driver error / lack of knowledge. Cars that live totally in town can struggle and repeated incomplete regens don't do you any favours (i.e. turning the engine off mid-regen). Knowing a little about them can cave a costly bill later.
    In all honesty, if you do a decent bit of mixed mode driving, regens will occur without interrupting anything or causing bother... other than the bother of looking at your fuel consumption during the process!!!
    Mine usually takes around 15 mins and happens once per tankful.
  1. regen
    By marko1966 in forum Vectra C / Signum Troubleshooting
    Last Post: 18th September 2012, 07:36
  2. Vectra 1.9 CDTi regen - This consistent with one . . .
    By Coupe2T in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2011, 16:42
  3. Bad Battery Regen causes Lumpy CDTI idle ?????????
    By thefibreguy in forum Engine & Drivetrain
    Last Post: 9th July 2011, 19:39
  4. DPF & Regen??? WTF!
    By Rab in forum Diesel Engine related
    Last Post: 28th September 2010, 13:05
  5. Particle Regen (3.0 V6 CDTi)
    By _x_Phoenix_x_ in forum Engine & Drivetrain
    Last Post: 25th November 2009, 09:55
