Thread: Clutch replacement - how to anybody ?
    Jun 2011
    United Kingdom
    Default Clutch replacement - how to anybody ?
    Hi all, what is involved with changing the clutch on a 1.8 z18xe please ?
    Ive done a few on older cars, mk3 astra v6, corsa etc... just wondering if these are similar ?
    Also do the clutch slave cylinder things need to be replaced with the clutch ?
    Or can I simply buy the clutch and pressure plate only ?
    Thanks very much
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    If your gonna have the gearbox out fella it pays to change the whole clutch assembly and the slave cylinder as well as sods law will mean something will fail
    Regular Member Das's Avatar
    Here
    35 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Probably one of the easier ones to do due to there being less of an engine and more room to work around. Its still a case of dropping the subframe, at least on the NS. Dunno why VX opted for this stupid system, mk1 and 2 astras and mk 2 and 3 cavaliers were a 45 minute job. Might as well do the slave at the same time as it inside the bellhousing and as easy to do at the same time.
    Jun 2011
    United Kingdom
    Cheers guys, so the box wont slide out from the side with the wheel off on these I take it ?
    So its a matter of dropping subframe, removing clutch cable, gearbox mount, all the bolts around the box and off it comes ?
    Thanks again
  1. Vectra C SXi 1.8 Clutch Replacement
    By allenrs in forum Engine & Drivetrain
    Last Post: 23rd October 2012, 06:40
  2. Who's done a DIY clutch replacement?
    Last Post: 13th October 2012, 21:02
  3. Clutch Replacement
    By hothatch in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2012, 11:33
  4. DMF Clutch replacement
    By Rupster_69 in forum Engine & Drivetrain
    Last Post: 20th February 2012, 21:12
  5. diy dmf and clutch replacement
    By 9tjc in forum Engine & Drivetrain
    Last Post: 20th December 2009, 23:34
