Thread: mot failure brakes
    wales
    Default mot failure brakes
    hi hope someone can help with this my vectra 2ltr dti 04 reg has just failed mot reason for refusal
    1, brake pedal creeps down under servo assistance and touches the floor .the brakes work fine it passed on the rolling road but when you apply the brakes the pedal gets hard then goes soft and you can push it further down till it hits the floor ? well confused mot tester says could be servo or abs unit help plz
    Engine : 1.9 CDTi
    Does it hold pressure without the engine running?
    If it does.......Pump the peddle a few times and hold it under pressure......With your foot still on the peddle start the car......If it goes down then yes its the servo.
    Mileage : 000
    Could be the seals in the master cylinder.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Sounds like servo mate
    wales
    thanks guys hope its just the servo
  1. Mot failure
    By tangoman in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 1st June 2012, 20:59
  2. Replies: 14
    Last Post: 3rd September 2011, 20:23
  3. VVT failure!!!
    By Pecojess in forum Engine & Drivetrain
    Last Post: 5th May 2009, 19:10
  4. DMF Failure
    By iainm in forum Engine & Drivetrain
    Last Post: 21st January 2009, 12:44
  5. MOT Failure
    By R13hard in forum Vectra C / Signum Car Chat
    Last Post: 25th June 2008, 19:22
