Results 1 to 10 of 11
Thread: Sky Dish help
    Birmingham
    Default Sky Dish help
    Chaps,
    I need some help please.
    I have sky but only as freesat.
    Whenever it rains I suffer really badly to get a signal.
    In fact even a few light spits of rain and it starts to say couldnt find channel/signal.
    What could this be?
    I have tried a different box and the same thing....is it the LNB?
    Bye bye Vec B
    - Hello Siggy!
    New Member Dave Greaves's Avatar
    Mar 2011
    Bolton
    It could be alignment of the dish is out. If your box has a signal strength indicator its quite easly realigned but easier with a signal strength meter from Maplin. Wipe any crud from the front of LNB first.
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Vehicle : Vectra C estate
    Trim : SRI
    Mileage : 79000
    As above go into settings menu and check signal strength when it's dry, it should be at least 3/4 full, if not either adjust the dish manually with somebody watching the signal it get a signal checker from maplins or eBay
    Jun 2011
    Elland
    Ditto above, but also look for any trees / branches nearby. I get the same problem when it rains, the branches get wet and heavy and get in the way of the dish. Worse if the dish is slightly out of alignment. With the branches removed, mine will still give a good pic in fairly bad rain!
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    If I open the left one (nearest the dish) of the three front windows on our house it partially blocks the dish and causes issues, it's amazing how sensitive they are, look for anything blocking it that may be weakening the signal, but yeah probably just wants re-aligning, high winds can knock it out of alignment very easily.
    Regular Member Jezzy's Avatar
    S.E
    I blame Rupert Murdoch.
    Regular Member CH-VECTRA-ELITE's Avatar
    Frimley
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 140000
    I brought one of these satellite finder kits, loads on ebay
    http://cgi.ebay.co.uk/SATELLITE-FIND...item519a1a640a
    and installed sky + on my parents place and improved their signal, they are right in the flight path of heathrow so nearly everytime a plane went by the picture would break up.
    I then also installed one of these
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
    you can have one on each cable, but I only put it on one, brought their signal strength from about 65% to 95%.
    2 very cheap ways to boosting your signal and much cheaper than calling out a sky engineer.
    Hope this helps, chris
    Birmingham
    Hi Chris,
    Slightly delayed reply but I have just bought one of those Sat Finders.
    Will see how I get on.
    Is it easy to use?
    Thanks, G.
    Bye bye Vec B
    - Hello Siggy!
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    WGAF#5
    phew .... read the thread title and thought you were planning a retrofit onto the Signum ...
    agreed with Ian the slightest thing on signal strength can kick it off even a tree now blooming after all the rain we have had !!
  1. dish/vxr alloy pics help
    By macka85 in forum Styling
    Last Post: 22nd April 2010, 14:11
  2. New Mobile Satellite Dish
    By JuzzyD in forum The 'Off Topic' room
    Last Post: 12th December 2008, 12:49
  3. Fitting a LNB to a sky dish...
    By Jim Bob in forum General Chat
    Last Post: 28th September 2007, 09:12
