Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: Can u lose power with a dump valve 2.0t
    Worksop
    Default Can u lose power with a dump valve 2.0t
    As above going to fit mine next week
    Seen a few posts were it says go into limp and u can lose power? Surely not with a decent quality dump valve like a Bailey etc
    Regular Member Jezzy's Avatar
    S.E
    If you're going to disable or bypass the factory-fit one, then yes, the car will be slower. The standard one allows the turbo to keep spinning even when you take your foot off the accelerator, thereby reducing spool-up time and lag. An after market dump valve won't achieve that.
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    16 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    My car had an aftermarket dump valve fitted when i bought it..soon as i bought the car i got a BSR stage 1 remap..
    How can i check if the valves affecting performance
    lincolnshire
    unless you change gear reeeeaaaallly slowly a i think the power loss will be so small you wont notice , you will however feel the woosh of the boost kicking in a bit more than before
    S.E
    The turbo spins at well over 100,000 RPM on full boost - the speed of your gear change isn't going to diminish turbo lag caused by the turbo having to regain that momentum.
    in a house
    Is that one of the reasons why the revs dont drop too quick either in between gear change?
    Worksop
    Can't see any power loss if it's holding boost with a dump valve
    S.E
    Quote Originally Posted by tomo41 View Post
    The clue is in your sentence: "holding" and "dump" are complete opposites. Dump valves dump the boost into the atmosphere, so the engine certainly won't be "holding" the boost with an aftermarket dump valve.
    S.E
    Quote Originally Posted by philgst View Post
    No, with the factory setup on the Z20NET the engine can drop revs whilst the turbo doesn't, as the boost keeps the turbo spinning whilst bypassing the cylinders.
    Worksop
    I meant if it's holding boost while on the gas it can't lose power surely then dump it then back on
  1. engine man light & lose power
    By Silver Vectra C in forum Engine & Drivetrain
    Last Post: 24th April 2012, 08:00
  2. car starts to lose power in 4th
    By myelite150 in forum Engine & Drivetrain
    Last Post: 31st December 2011, 12:32
  3. lose of power when overtaking
    By iansfocus in forum Vectra C / Signum Troubleshooting
    Last Post: 6th October 2010, 22:35
  4. Decat - gain or lose power?
    By mucklestone in forum Petrol Engine related
    Last Post: 28th February 2010, 13:31
  5. Replies: 23
    Last Post: 6th March 2009, 09:00
insignia 2.0t dump valve
vauxhall vectra c 2.0 t dump valve
