Results 1 to 10 of 24
Thread: traction control
    Jul 2011
    UK
    Year : 06
    Default traction control
    hey all
    Anybody here no if the traction control switch would work in my veccy sri 2007
    West
    iirc tc was removed from facelift models unless you had ids+
    May 2011
    bispham, blackpool
    Quote Originally Posted by marc vectra sri View Post
    hey all
    not sure
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Take the blank off and see if there is a connector behind. If there is, borrow a switch to see if it works, if it does, go buy one
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    2007 model it is unlikely to work as Vx removed the cabling although the plug may still be there and/or they have removed the TC function altogether from the 2006 models onwards.
    May 2011
    bispham, blackpool
    Quote Originally Posted by Gazza4 View Post
    theirs a how to on here somewhere how to turn the tc off without the button by having engine running and quickly switching the ignition off and then on fast enough so the engine doesnt turn off and then tc turns off tried it on a 2003 sri and it worked but havent a clue for a 2007 model but it worth a try then you will not need the button
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by 6009tristanb View Post
    If the switch is there and TC is present, as far as I am aware all you need to do is run a feed from the blue plug in the dash where the TC button should go to the ABS module or something - I think.
    Regular Member Hummelshøj's Avatar
    Aug 2009
    Denmark, Kolind
    Vehicle : Vectra C OPC Estate
    Trim : OPC / VXR
    Engine : Z28NET
    I have a 2006 VXR 255bhp with IDS+. And the plug is in the car.. I then bought at switch but its still not working... It missing a wire I thin.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Hummelshøj View Post
    Yeah the VXR's will have it as they will have the extras as standard like IDS - don't know if they have the ESP though.
    Jul 2011
    UK
    Year : 06
    Hmm I will have to take the blank off see if I have got plug knowing my luck won't be or will be but won't work lol
  1. my traction control how to
    By jpbroad1970 in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2012, 20:01
  2. traction control
    By ggg1979 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2009, 18:07
  3. 2.0T Traction Control
    By kryton01 in forum Engine & Drivetrain
    Last Post: 20th October 2009, 17:18
  4. traction control
    By jsnlvxr in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2009, 21:56
  5. traction control
    By jamesv6 in forum Vectra C / Signum Car Chat
    Last Post: 14th August 2006, 00:13
