Results 1 to 10 of 20
Thread: vac pipes oil on top of them
    Jul 2011
    retford
    Default vac pipes oil on top of them
    guys, the 2 metal vac pipes on the cdti 150 that run over engine block....
    i have oil on top of them, cleaned off and driven, theres oil on them again...
    any ideas????
    Jul 2011
    retford
    ive replaced the vacuum pipe for silicone, but its the metal hard pipes with oil resting ontop of them!!!!
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Are the swirls knac****d, if so the oil residue gets soaked into the underside of the beauty cover then will wet/soak onto other pipes it comes into contact with, but pics would help with this diagnosis.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by the-wizard View Post
    mine was the same, if not the oil breather for the cam cover is not sealed properly (most like due to a knackered clip on the pipe). This would also do the same. Due to your CDTI 150 being 2004 I am more inclined to agree with wizard, swirl flaps are the more suspect.
    Photos would really help, as on another thread I got the impression the vacuum pipes were missing.
    Jul 2011
    retford
    right, just been out, ive disconnected both vac lines and run from the pump to the boost sensor thing. 2nd vac pipe not connected, car runs much smoother now.
    no 4 swirl is oily yes, but bar connected and free moving
    the oil breather has no clip ive just noticed, this cause an issue, doesnt seem to tightly connected
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by james walker View Post
    I would say both are the issue then. You disconnected the vacuum pipes and it's running smoother, I presume on idle only? Thos vacuum pipes operate the turbocharger. Then the vacuum is sufficient enough the turbo vanes open and this generates boost. Without the vacuum the engine won't run with very much power.
    Jul 2011
    retford
    the vacuum is connected from the pump to the boost valve only, car runs much much better like this.
    yeah, ill get a jubilee on the breather and see if this helps, cheers fellas
    north east
    Can you post a pic of how you have the pipes connected.
    Jul 2011
    retford
    http://www.vectra-c.com/forum/showthread.php?t=109454
    post 6, the 2 metal pipes on mine have no silicone pipes attatched. the pipe from the bottom of the pump goes to the valve circled in blue......
    runs fine like this, but obviously aint right, can any one shed any light?
    when engine on the 2 metal pipes with open ends produce no vaccuum or anything.
    hmmmh
    Jul 2011
    retford
    also the oil i think has come from the breather pipe which was missing a clip and spurting out under pressure, i have reclipped this now....
    just want confirmation on the pipe layout and what function these 2 metal pipes have..
  1. oil in air pipes
    By beat275 in forum Vectra C / Signum Troubleshooting
    Last Post: 9th October 2012, 13:34
  2. New pipes on the way
    By rob1981 in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2012, 07:49
  3. pipes pipes pipes
    By Garfo in forum Diesel Engine related
    Last Post: 10th June 2011, 16:55
  4. Vac pipes
    By corderz in forum Diesel Engine related
    Last Post: 2nd February 2011, 13:29
  5. Pipes
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2006, 16:55
