Thread: 1.9td 16v 5th and 6th gear not working
    luton
    Default 1.9td 16v 5th and 6th gear not working
    Hi something really odd is happening, gears 1-4 fine, Change to 5th and the engine only appears to fire on a couple of cylinders and all the power goes, regardless of revs, any ideas, same for 6th, ok if I floor it though, any ideas?
    luton
    Anyone ?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Strange one
    Have you had the codes read?
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    When do you go into 5th and 6th, at what speeds?
    Insignia VX-Line Nav CDTI 170.
    luton
    About 60 for 5th, and 6th at 70, but even if I red line 4th, and then change to 5th so the revs are a lot higher, it still does it.
    Jun 2007
    Scotland
    Vehicle : Insignia
    Year : 2015
    Mileage : 27000
    Quote Originally Posted by gdansk View Post
    Does the flywheel rattle?
    Is the car's low down power affected in anyway?
    luton
    Hi, no rattle, and seems to be down on power through the rev range. It's just like its not firing on all cylinders. It was subtle at first, I almost thought it was my imagination, then the last couple of days its just got worse. As long as I don't use 5th and 6th its fine. Occasionally they will work.
    Haven't had the codes done yet as its only just started doing it. It's an 08 plate, with 43000 miles on
    Jun 2007
    Scotland
    Vehicle : Insignia
    Year : 2015
    Mileage : 27000
    I would say it's affecting all gears, it's just 5th and 6th gears will be more noticable as they make the engine work harder. Check the vacuum hoses first. If you lift the vanity cover off of the engine, and look directly down on top it, you will notice two hoses on the bottom right near the grille. They have a tendancy to split. These vacuum hoses are what the engine uses to operate the turbo. So if there's a leak you will have no turbo.
    I wouldn't be surprised if the old EGR valve problem is afoot here either.
    luton
    Quote Originally Posted by Gazza4 View Post
    cheers, i'll check those
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2016, 16:15
  2. radio working, not working, working again
    By J P S in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2012, 00:59
  3. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  4. Replies: 0
    Last Post: 10th November 2011, 22:58
  5. Cruise control not working in 5th gear??
    By Ademusic in forum Engine & Drivetrain
    Last Post: 27th April 2011, 11:43
