Thread: Z30DT fuel filter
    Aug 2009
    Ascot
    Default Z30DT fuel filter
    As above where is the best place to get a fuel filter
    Nick
    Regular Member Hummelshøj's Avatar
    Aug 2009
    Denmark, Kolind
    Vehicle : Vectra C OPC Estate
    Trim : OPC / VXR
    Engine : Z28NET
    At the dealers--
    Aug 2009
    Ascot
    Yeh but vauxhall are £35!!!!!!
    Jun 2011
    Elland
    My stealers charged around £11 for a filter element. Local motor factors charged half that for the same FRAM filter element. I have a spare you can buy, as I replaced my filter housing and engine bay pipework with bespoke stuff, as I was having trouble with some failed quick release joints. A tenner and it's on your doorstep, if you want it.
    When changing the filter, unless they have changed the system, there is no lift pump, so you have to top the filter up with diesel - it's a bit fiddly to get them primed, but I put the filter in, then held the top of the housing down whilst pouring diesel in through the bolt that holds the housing together. Then, with pressure maintained on the top of the housing with one hand, insert and tighten the bolt and you should end up with a filter full of fuel. I have a 55 plate sig 3.0 Z30DT. Mail me hebblemarine@yahoo.com if interested.
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    I got one from my local motor spares £9. Works like a charm.
    Aug 2009
    Ascot
    My bad (seriously embarrassed ) I ment oil filter
    Nick
    Aug 2009
    Ascot
    Default Z30DT oil filter
    Hi,
    After an embarrassing typo error!!!! Were is best place to get OIL filter as vauxhall want £35!!!!
    Nick
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    A think a seen someone say the otherday europarts soba Saab one for 11quid
  1. Fuel Filter Replacement - Z30DT
    By ph67 in forum Y & Z30DT Specific
    Last Post: 23rd August 2015, 13:45
  2. Z30dt fuel filter question.
    By ScottyV6 in forum Y & Z30DT Specific
    Last Post: 21st November 2012, 23:41
  3. Z30DT Fuel Rail
    By mattoct in forum Y & Z30DT Specific
    Last Post: 21st September 2012, 10:53
  4. Z30DT Fuel Rail
    By mattoct in forum Engine & Drivetrain
    Last Post: 5th September 2012, 16:37
  5. Replies: 19
    Last Post: 30th May 2012, 15:53
z30dt diesel filter change
