Results 1 to 3 of 3
Thread: Exhaust gas recirc flow prob P0400?
    Ripon, North Yorkshire
    Default Exhaust gas recirc flow prob P0400?
    This error came up when really hot in standing traffic today.
    P0400 - Exhaust Gas Recirculation Flow Malfunction
    Car is 3.0 V6 diesel 2005
    This sounds like something related to EGR valve?
    N
    Engine : 1.9 CDTi
    On my 1.9 CDTi that code was EGR related.
    cleaned it and all is wel.
    Jun 2011
    Elland
    The ECU looks at the fresh air flow in (MAF sensor) and the boost pressure (manifold pressure) and temperature. From this it can work out the amount of exhaust gas recirculation taking place. If it's not within some set limit, then a code is thrown (this happens whan the EGR is blanked). If the valve is faulty / dirty / sticking, then that situation could arise.
    Could be worth taking it off for a clean as lee gsi suggested. Else it could be kaput. EGR function can be checked on tech2 etc if you don't want to get your hands dirty.
  1. P0400 - Exhaust Gas Recirculation Flow Insufficient Detected
    By lencuff in forum Y & Z30DT Specific
    Last Post: 20th November 2012, 18:15
  2. P0400-F8 Exhaust Gas Recirculation Valve Feedback Signal Malfunction
    By Vectra Forever in forum Engine & Drivetrain
    Last Post: 30th June 2011, 15:19
  3. P0400 - EGR Flow Malfunction
    By BigMart in forum Engine & Drivetrain
    Last Post: 30th May 2011, 22:07
  4. P0400-5B Exhaust Gas Recirculation Flow Excessive Detected
    By zafira in forum Diesel Engine related
    Last Post: 11th September 2010, 07:46
  5. New Power Flow Exhaust
    By nutron in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2006, 22:56
