Thread: Egr valve coolant pipes
    Jun 2011
    YORK
    Default Egr valve coolant pipes
    I have just finished cleaning the egr valve on my vectra c 02 and have put everything back together.
    However when I first took one of the coolant pipes off i lost around a cup of coolant as i didnt get to stop it in time.
    Im now afraid to start the car incase i damage something.
    Im a complete novice about cars but please can someone give assurance it will be ok?#
    Regular Member Vectra Forever's Avatar
    Apr 2011
    Somerset
    As long as you top up the coolant tank of the top right side of the car with water to the right marks which are embossed on the tank then you will be fine. The loss of a small amount of coolant is ok, providing the system wasn’t low in the first place.
    Top the coolant up with cold water from a boiled kettle to the mark “COLD” on the tank and you will be fine.
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    it needs topping back up to the "max when cold" mark on the expansion tank, but you should be ok realistically.
    Jun 2011
    YORK
    thanks, dont really do repairs and had to check in case i did something stupid. regards
  1. Brake servo Valve (one way valve)
  2. Replies: 6
    Last Post: 29th July 2012, 13:52
  3. Vac pipes
    By corderz in forum Diesel Engine related
    Last Post: 2nd February 2011, 13:29
  4. Egr valve, swirl valve problems etc..
  5. V6CDTi coolant loss - heater bypass valve?
    By Celes in forum Engine & Drivetrain
    Last Post: 6th October 2010, 17:50
vectra c coolant egr
