Thread: rear view mirror was vibrating, now fallen off ... doh
    Oct 2006
    Lancashire
    Default rear view mirror was vibrating, now fallen off ... doh
    Had problems with micro vibrations from road surface transmitting through windscreen then through rear mirror making it very awkward to use it (you cant focus on anything you view in it) it seemed loose so have adjusted it around in past only for it to come back a few days later, tried moving it again before only for it to come off the ball joint at the windscreen end of the mount.
    Took metal mount off windscreen but the ball joint wont go back together (plastic inner retainer is damaged) so inner spring is now not tensioned. Guess a whole new vx mirror is needed, lucky its a manual dip rather than my old vectras auto dip, are manual dip mirrors standard across the insignia range or indeed used on different vx cars e.g astra? Maybe get one from a breaker rather than stealer!
    Regular Member poves's Avatar
    lancashire
    You lost me on what car it is lol ?
    If it's a vectra / astra etc any other vx mirrpr will fit from same age across the model range - astra - vectra - corsa.
    I'm pretty sure the insignia is a completely different fitment.
    Oct 2006
    Lancashire
    Quote Originally Posted by poves View Post
    its an insignia (sri 160) ... hence posting in the insignia sub forum ;-)
    lancashire
    Yes the insignia is a completely different fitment , I've only had to take one off and refit but it was a while back.
    A bit more involved of a job to remove "iirc" , very tight fitment , I also have a feeling that there is a retainer grub screw that holds the mirror to the screen bracket , it will be obvious if it has.
    Just be sure to get the correct mirror in regards to autodim and sensor wiring etc.
    lancashire
    Quote Originally Posted by stehanson View Post
    My bad , I don't post much on the forum anymore , not used to the insignia owners being here
  1. Rear view mirror
    By wayne10244 in forum Bodywork & Interior
    Last Post: 16th February 2012, 20:11
  2. Rear View Mirror Blocks all View to Left
    By bren in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2008, 21:36
  3. rear view mirror
    By kpf1grandprix in forum Electrical & ICE (including SatNav)
    Last Post: 6th April 2008, 17:19
  4. Rear View mirror
    By 2.2DTISRI in forum Troubleshooting
    Last Post: 6th March 2008, 13:03
  5. Rear view mirror
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2007, 23:02
insignia rear view mirror vibration
