Thread: Taking Ignition live from REC in Signum?
    Engine : 1.9 CDTi
    Default Taking Ignition live from REC in Signum?
    I am in the middle of fitting a rear accessory socket and wiring in the Travel assistant.
    Rather than using the piggy back fuse holders I was thinking about using a spare fuse space for the ignition live source.
    My spare fuse holes are: 1,2,3,5,8,12,13,18,22 and 29.
    If I do need to use the piggy back fuse ones where is is best to take the TA power and a Accessory power?
    Regular Member Jonsey's Avatar
    Oct 2010
    Walkden, Manchester
    when I installed my Amp in the boot on my hatch, I just used one of the free maxi fuse spaces for the main 12v feed rated 40A but used 20A in line fuse (think it was the heated rear seat one)
    And for the switched feed I used the bottom small fuse space, one on the right as you look at it, all I did was use spade connectors and pushed it into the slot. HTH
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Wasn't there a How To for this recently, using a piggyback fuse connector?
    Regular Member husky's Avatar
    Edwinstowe
    Trim : VXR-D
    Engine : 1,9 CDTi 150
    Why not just add the wire into the REC that the estate used for the aux socket , that's what I did in the boot of my hatchback
    Engine : 1.9 CDTi
    Quote Originally Posted by husky View Post
    How ?
    Engine : 1.9 CDTi
    And where can I get the piggy back fuse's from?
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
  1. Wiring an amp, need an ignition live and permanent live in the boot
    By inchy1981 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2012, 16:36
  2. Ignition live
    By dazza3674 in forum Electrical & ICE (including SatNav)
    Last Post: 6th May 2011, 20:46
  3. ignition live
    By glynn in forum Electrical & ICE (including SatNav)
    Last Post: 15th October 2007, 20:03
  4. ignition live
    By kenny22 in forum Electrical & ICE (including SatNav)
    Last Post: 14th June 2007, 22:35
  5. Taking Power Outlets off Ignition?
    By chrisschild in forum Electrical & ICE (including SatNav)
    Last Post: 4th July 2006, 19:33
