Thread: Engine cutting out when turning right
    Oct 2006
    Surrey
    Default Engine cutting out when turning right
    Has anyone experienced this problem before?
    When turning sharp right everything dies includinging the engine.
    Is this a known wiring/steering loom problem.
    Car is an 04 2.2 Sxi
    Do you mean you get complete electrical failure????
    If so, it points at the battery, had one before that did that..the battery terminals were loose..
    Oct 2006
    Surrey
    Apparently so. It's not my car, it belongs to a neighbour.
    It just seems to happen when turning hard right.
    Regular Member Nige's Avatar
    May 2006
    Derbyshire
    I had a similar problem on an old Porsche I had, fault was the air box/intake, it had a flapper like devise that was spring loaded, the spring had weakened so when corner hard in one direction the air flow was cut out so the engine stalled. Don't know if it could be a similar thing, just a thought.
    if it's your neighbours car, check the battery's securely held in the battery tray and check the terminals are firmly on the battery.. also check the earth point where the earth lead connects to the body.. had one before where all that was left jioning the wire together was the outer insulation, the wire appeared sound but had no continuity.
  1. engine cutting out.
    By jas is ace in forum Engine & Drivetrain
    Last Post: 5th August 2011, 21:05
  2. Replies: 3
    Last Post: 28th April 2009, 19:49
  3. Engine cutting out
    By Sean-2.2Direct in forum Engine & Drivetrain
    Last Post: 30th October 2008, 16:14
  4. Problem when turning engine off!
    By user999998 in forum Engine & Drivetrain
    Last Post: 17th June 2008, 01:25
