Thread: Tyre Replacements and Metal Valves
    Regular Member ukanalyst's Avatar
    Jul 2006
    Cheshire
    Default Tyre Replacements and Metal Valves
    Hi guys,
    I've just bitten the bullet and spend £230 on a pair of new front tyres Ouch! not great considering the car's only done 14,000 miles
    My car apparears to have metal valves (but not TPMS) ... do I need to tell the tyre fitters to do anything special do you know?
    Dave
    The Blackburn End
    What did you go for in the end ?
    Jul 2006
    Cheshire
    Toyo Proxies T1-R's from Black Circles ... found a 10% Discount Doobery so cost is £228.40 all in
    Jul 2006
    Cheshire
    Nothing special then that anyone knows of?? I assume they will just fit a new metal valve??
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    They should only check the valves for leaks/damage and if ok leave them there.
    spoons
    Guest
    So whats the difference between a metal valve and the usual rubbery ones. Apart from the obvious?
    Jul 2006
    Cheshire
    Thanks for the info Tyreman ... do you know how they should check for leaks? (I'm quite worried now as the centre I have chosen to have them fitted at I have been told by someone at work is owned by a cowboy ... her husband used to work for them apparently so really want to keep an eye on them and know what they should be doing.)
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Before letting the air out 'paint' soapy water(or similar) around the valve to check for bubbles,similar to doing a push bike puncture !.Metal valves are bolted through the rim, they're normally fitted to high performance stuff (meant to be less prone to leaks),the only problem is letting a tyre fitter near your wheels to tighten them as i know to my cost.
    Jul 2006
    Cheshire
    Quote Originally Posted by tyreman
    OK Now I'm very very scared! ... I will be watching them like a hawk!! Thankyou for the info by the way.
    Dave
  1. Sounds like metal-to-metal from the rear.
    By Vaux-Man-G in forum Suspension, Wheels & Brakes
    Last Post: 2nd April 2014, 12:01
  2. For Sale: Snowflake tyre valves
    By SRIDAN in forum Parts for sale
    Last Post: 1st February 2012, 10:35
  3. Vectra-B brakes sound like metal to metal
    Last Post: 4th December 2011, 14:42
  4. Tyre valves
    By david173 in forum General Chat
    Last Post: 26th April 2006, 19:13
