Results 1 to 10 of 13
Thread: Rotary advice
    Aug 2006
    Is a very naughty boy
    Default Rotary advice
    Ok, so I have had a DA for a while and recently saw someone using a rotary. I couldn't believe how much faster it was than the DA.
    So are they worth it? I know they are more risky but is it easy to damage the paint if used correctly?
    I guess I can use the same pads and stuff, just need a new backing plate to match.
    Anyone got both?
    Mar 2010
    Trim : Design
    Engine : 1.9 CDTi
    Its very easy to damage paint with a rotary as it will build up heat loads quicker.
    Aug 2006
    Quote Originally Posted by lee gsi View Post
    Do you have one? have you tried it?
    I realise this and have watched the vids on DW. TBh watching them, I was thinking that as long as you keep an eye on the temperature and keep it moving across the panel then the risk is kept to a minimum.
    Regular Member sristeven1's Avatar
    Feb 2009
    wirral
    i got a rotary as long as you keep it moving and not work 1 panel for to long they are fine just got to extra carefull with them
    Mar 2010
    Trim : Design
    Engine : 1.9 CDTi
    We have a bodyshop next to where I work.
    They let me have a play on an old panel and I took the paint off on the bump strip and crease in the door in about 10 seconds.
    Aug 2006
    Quote Originally Posted by sristeven1 View Post
    Thats what I was thinking. have you ever left marring or anything? Noticed any damaged?
    Pad/polish combo????
    What pads/polish did you use? I cannot imagine that being careful and after using a DA that doing what you say you did in 10 seconds is all that easy. I have watched videos where its taken ages in one section to burn the paint/pad.
    Regular Member happypostie's Avatar
    Slough
    131 Post(s)
    Vehicle : insignia vxr
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    vauxhall paint is soft so im told . ive just bought some new hex pads and was told that the green one should be used for heavy compounding and the white one as a rule is the one you will use most ,as it will compound lightly but also polish . im still using a da but still playing with the rotary that ive also got . khalid
    Nov 2007
    DERBY
    25 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    The sealey rotary i just bought has 6 different speed settings..hopefully idiot proof.
    Aug 2006
    Quote Originally Posted by happypostie View Post
    I've been using the orange polishing and red finishing elite car care pads.
    my da just seems to take ages. Maybe a harsher pad or polish would be a better option?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Mileage : 137000
    Rotary's are fine mate. As said keep the speeds down, keep it moving but the big thing I find is with a DA, when you hit an edge you have more time to move off before you strike through, but with a rotary they can strike through very easily on an edge as the pad spins in the same place.
  1. Rotary Advice...
    By Dan_BlackSRi in forum Detailing and Car Care Discussion
    Last Post: 26th June 2009, 07:29
  2. First go with a rotary.
    By Stevel in forum Detailing and Car Care Discussion
    Last Post: 19th October 2008, 10:17
  3. rotary polisher
    By skippyroo in forum General items for sale
    Last Post: 10th July 2008, 02:12
  4. Rotary Polishers
    By Brocks in forum Detailing and Car Care Discussion
    Last Post: 25th June 2008, 09:42
  5. How to use a rotary buffer
    By DNS in forum Detailing and Car Care Discussion
    Last Post: 18th March 2008, 15:36
