Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
Thread: Sidelights on with ignition
  1. #11
    Full Member Robsey's Avatar
    North East Cheshire
    30 Post(s)
    Trim : Energy
    Mileage : 150,000
    There are five options on the DRL set up in the underhood module
    These are:-
    No DRL's
    Side lights as DRL's
    Dipped lights as DRL's
    Front Fogs as DRL's (Illegal in this country)
    Adaptive Forward Lighting as DRL's
    You can also have the REC programmed for DRL's, if you wish the tail lights to come on with the ignition..
    Just a point of knowledge... TIS will not tell you what the 4 DRL options relate to, and if you try going through them all in one go, then the UEC (underhood module) gets confused, and you find that either your front fogs or headlights will not turn off.
    The only cure is to pull the main battery for half an hour.
    All should be set to your last setting when you refit the battery.
    Otherwise the fogs or headlamps should work as normal.
  2. #12
    North East Cheshire
    30 Post(s)
    Trim : Energy
    Mileage : 150,000
    Quote Originally Posted by Jonsey View Post
    Wonder if something can be done to the sidelight output wire from the back of the switch, like disconnect it from the switch connector and connect to switched ignition feed.
    Don't know how the wiring in the switch works tho due to being half-can
    Nope you cannot do this, because all the contact wires operate at a specific resistance / voltage, to tell the BCM which lighting function that the UEC needs to fulfil.
    What you can do is pig about with an ignition controlled relay, that can short the two relevant solder pads within the switch unit.
    I did something similar to this on a lighting unit to control the illumination of my CD70 in my 1994 Cavalier Mk3.
    A bit of a fiddle to get two wires in but doable, as I found out when I put extra wires in the wife's Vectra-C light switch unit to fit non-CAN controlled front fogs
    Half CAN wiring is no different.
  3. #13
    Ely, Cambridgeshire
    63 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Slightly confused about your previous post Robsey, are you saying that DRL's set to side lights can be set via Tech 2/Op-com so that the minute you start the car your side lights come on at the front?
    Because if so, can you be more specific as that's exactly what I'm looking for and would save a lot of wiring in relays etc lol
  4. #14
    North East Cheshire
    30 Post(s)
    Trim : Energy
    Mileage : 150,000
    That is exactly what I am saying
    Bear with me a minute, whilst I look at a post on a different forum
    (which I cannot mention on this forum).
    Okay.. as described on the other site.
    Thanks to the Vectra-C member who posted this response.
    Option 1 is sidelights,
    Option 2 is headlights
    either 3 or 4 is factory fitted or CAN controlled front fogs...
    and the other option is for Adaptive Forward Lighting ..
  5. #15
    Ely, Cambridgeshire
    63 Post(s)
    Year : 2010
    Cheers Robsey. Do you know if this is an option with half-can as well as full-can cars?
  6. #16
    North East Cheshire
    30 Post(s)
    Trim : Energy
    Mileage : 150,000
    Yes it is an option for ALL Vectra-C's
    I have found when fitting modules to my Cavalier, that I can happily mix and match half and full CAN components..
    I used half CAN BCM and CIM alongside full CAN CD70, GID and lighting switch.
    TIS does not specify any differences in the wiring within and between the components.. only the half-CAN infotainment system.. which with regard to DRL's is irrelevant
  7. #17
    Ely, Cambridgeshire
    63 Post(s)
    Year : 2010
    Great thanks fella, that's going to save me a bit of work
  8. #18
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    I would be interested in this too but did an earlier post not say the the dips come on too?
  9. #19
    North East Cheshire
    30 Post(s)
    Trim : Energy
    Mileage : 150,000
    Do bear in mind about how to go about programming if you are doing it yourself.
    The UEC does get confused easily - lol
    PM me if you any more info.. or links to the "other" forum.
  10. #20
    North East Cheshire
    30 Post(s)
    Trim : Energy
    Mileage : 150,000
    Quote Originally Posted by Gazza4 View Post
    It depends upon which Option you click during programming
    I assume that he must have clicked on option 3 to have side and dipped lights on. (where fogs are not factory fitted / CAN enabled).
  1. None LED sidelights
    By ridgers84 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd January 2012, 02:34
  2. LED Sidelights???
    By Governor in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2011, 00:03
  3. help with sidelights please
    By carlsondavid33 in forum Styling
    Last Post: 6th November 2010, 21:26
  4. sidelights
    By WKD-mcc in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2009, 16:21
vectra side lights with ignition
where to wire halo rings in vectra c site:www.vectra-c.com
what would cause Astra front side lights to be on with ignition
