Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Sidelights on with ignition
    Regular Member Jonsey's Avatar
    Oct 2010
    Walkden, Manchester
    Default Sidelights on with ignition
    How would i get the sidelights to come on with ignition, bypassing the switch, also would this cause an MOT fail?
    Whats the easiest way to do it, without running a new set of wires to the front & back lights.
    Engine : 1.9 CDTi
    TECH2 or Vaux-com type program can do it.
    Shame your not closer.
    Oct 2010
    Walkden, Manchester
    Quote Originally Posted by lee gsi View Post
    I have tried that, sidelights come on with ignition but when engine started headlights come on to.
    Engine : 1.9 CDTi
    Ah thought thats what you wanted.
    No real point having side lights on in the day as you wont see them.
    Probably why its not an option but to put dipped beam on.
    Don't do it. Don't become a Volvo driver.
    Engine : 1.9 CDTi
    All 2011 cars need DRL now so its not just Volvos lol
    DRLs aren't dipped headlights though, and it's only the front of the car that's illuminated.
    Ely, Cambridgeshire
    60 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Been seriously considering doing this myself with my angel eye halos as I have them on all the time anyway as a rule, but now I've changed to LED's in the halos, they strobe if I don't have them on, so was planning to rig them to an ignition live so that the front angeleyes came on as soon as I turned the car on. Only downside I can think of is battery drain if I don't actually start the car, but they're LED's so that would be minimal anyway.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    I found out today, that if you remove and unplug the light switch, your dips come on and off with the ignition. Safety feature???
    Cheap DRL's!! However, you'll not have a working rear fog light = MOT failure.
    Oct 2010
    Walkden, Manchester
    Wonder if something can be done to the sidelight output wire from the back of the switch, like disconnect it from the switch connector and connect to switched ignition feed.
    Don't know how the wiring in the switch works tho due to being half-can
  1. None LED sidelights
    By ridgers84 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd January 2012, 02:34
  2. LED Sidelights???
    By Governor in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2011, 00:03
  3. help with sidelights please
    By carlsondavid33 in forum Styling
    Last Post: 6th November 2010, 21:26
  4. sidelights
    By WKD-mcc in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2009, 16:21
