Thread: Which set up
    Regular Member johnnyboy1985's Avatar
    Aug 2010
    Letchworth Hertfordshire
    Default Which set up
    I know its been asked 1000s of times but id like some help.
    http://www.dcperformance.co.uk/cheap...it/tap672.html
    or
    http://www.venommotorsport.com/produ...ory=Suspension
    I know people have had trouble with fk coilovers which is why im put off and also worried it'll just give a crap ride....however it will look low does anyone have the above spax setup n any pics?
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    Fair enough i despise the fk coilover range but only had the cheapo nasty set.
    would assume the ones you are looking at will be of much higher quality and if i had the cash would consider them myself
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Do you just want the car to look low in which case get the Fks. If your primary concern is handling get a set of Bilstein B8's and eibach springs
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    I had the TAP670 on my old 2.2 saloon and loved it. Was going to put the TAP673 on my estate but decided I want it a bit lower than that so will be fitting H&R springs instead, but that's the ONLY reason I'm not fitting the Spax PSX kit again.
    The adjustable shocks are fantastic too. I used to run mine on setting 12 of 28 for normal use but could go softer or harder easily in about 30 seconds.
    Aug 2010
    Quote Originally Posted by Ian-Highlander View Post
    I looked at H&R springs but when you add the cost of shocks to it im spending £700+....H&R springs lower it by 40mm doesnt it? is that more noticeable?
