Thread: Blooming Window Washer Jets
    Nov 2010
    scunthorpe
    Default Blooming Window Washer Jets
    Hi all
    Got a 05 1.8 SRi. The window washers only trickle out after being held on for a few mins and got an MOT soon.
    When i bought the car - it was winter and had new jet nozzles so never used them. Since then - thought i better use them. Low and behold nothing was coming through.
    Replaced the pump the other day and then got a trickle - followed my friend to lincoln and he washed his vectra c front screen - the over spray cleaned mine. What should i replace next as im confused.
    Dont want to start buying bits that wont make any difference. It seems to come out of the pump ok - not sure how powerful its meant to be out of the pump without the pipe, same force before the nozzles but then nothing. Am i right to think i should just replace the nozzles again and guess that the shop never actually did it?
    Steve
    Oct 2006
    southampton
    15 Post(s)
    try cleaning out the tank, can get gunked up matey....
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Most likely the rubber filter blocked.
    http://www.vectra-c.com/forum/showthread.php?t=107593
    Nov 2010
    scunthorpe
    ****** me lol - the one thing i wondered why it came with the pump when i bought it and didnt use it haha - ill try cleaning the rubber grommet / filter tonight and see if that makes any difference.
    Cheers Guys
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    As Lizard says take the whole bottle out and give it a good clean out, they get gunked up if you don't use a good screen wash, the bottle gets green and black mouldy gunk building up which then ends up covering the filter.
    I bought the bigger washer bottle and you clearly see all the black gunk inside it.
    Before
    After
    VECTRA1974*
    Guest
    quick question what did u use to remove all the gumf inside
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    Flash Spray Bleach, one of those long handled spiky brushes and a piece wire with a bent end to get the last of the inaccessible area. However I have since found out that adding a handful of uncooked rice and shaking it around does a pretty good job too.
    11 Post(s)
    Quote Originally Posted by VECTRA1974* View Post
    Give it a good soaking in Milton sterilising fluid.
    I have been told steradent tablets work too.
    newport
    you can get at it and pull it out the bottle without even taking the wheel arch lining off, if you know what you are looking for, just feel up and behind the bumper just in front of the wheel, and there is enough room to pull it out
  1. washer jets
    By Al 22 dti in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2011, 07:40
  2. window washer jets not working
    By steve-wolves in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2011, 13:43
  3. washer jets
    By rickeys16v in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2010, 15:56
  4. Washer Jets
    By VikBee in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd December 2009, 09:06
