Thread: Original HID's are flickering
    Plovdiv, Bulgaria
    Default Original HID's are flickering
    Hello,
    I have original HID's fitted in my car. It's 2006 facelift Vectra C 1.9, 150hp. It's not BiXenon. The lights start to flicker recently. Not very bad but I can clearly notice it. Sometimes they even switch of for half a second. Any idea what can cause the problem? I tried to search for a similar issue but the only results I can find are for aftermarket HID's.
    Engine : 1.9 CDTi
    Do they both do it?
    Whats the battery voltage like?
    Plovdiv, Bulgaria
    Both are flickering. The battery is ok. That is the first thing that I checked. I will order new bulbs to see if that will help. I suspect the ballasts but can't be sure and are to expensive to replace. Just wanted to check if someone else had that issue before.
    stockport
    Arrow
    Quote Originally Posted by netrootbg View Post
    If they're shot,why don't you just replace them with aftermarket ones?.Then,when you come to MOT the car next year,if the new reg's have come in,they shouldn't fail them because all the necessary OEM support equipment will be as standard!!.FELIXX.
    Sodding Typical on Sea
    Get a pair of Ds1 bulbs off ebay in the colour of your choice,,,, simples,,,,,
  1. Flickering headlights
    By Mrpam in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2013, 23:12
  2. Lights Flickering
    By Alan/1967 in forum Electrical & ICE (including SatNav)
    Last Post: 10th October 2011, 14:20
  3. Flickering HID's....:(
    By Davies20 in forum Electrical & ICE (including SatNav)
    Last Post: 12th January 2011, 20:12
  4. led,s flickering
    By cranny 27 in forum Styling
    Last Post: 14th November 2009, 19:35
  5. Flickering HID'S
    By Bossybuggy in forum Electrical & ICE (including SatNav)
    Last Post: 27th December 2008, 22:29
