Results 1 to 10 of 14
Thread: Advice re polishing..
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Default Advice re polishing..
    Im about to enter the world of machine polishing,should be arriving tomorow..anyone got any hints n tips??????..what products do you recommend????
    Regular Member Ben_'s Avatar
    Audiville, WM
    What colour is it mate? And what condition is paint in. Have a good read through detailing section for top tips or get yourself on to detailingworld.com there's a good how to on machine polishing on there.
    HTH mate and good luck
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Im liking the Meguiar's Mirror Glaze range of products. They are easy to use and have an easy to read Cut meter on the front, reasonably priced at around £14-£15 for a 975ml bottle. I have #82 and #83 at the moment which is pretty much enough to cover most applications. I'm using Monza pads at the moment which are incredibly good value for money.
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    shes a bright red 03 plate..i've tried to keep on top of the paintwork by hand over last four years but havent been using anything special until i recently started to use autoglym kit..
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    That's mostly what I use, or #3 and #7, followed by #20 polymer sealant and/or #16 wax. Good stuff. I use the Chemical Guys Hexologic pads.
    Full Member Big Sig's Avatar
    DA or Rotary?
    Woodbridge
    No clear coat on that paint, so I would suggest you use a polish with a lower cut and a softer pad, dont be alarmed when it turns red. Take your time with it and have a good read through some threads on DW.
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Postman just delievered a sealey ms900ps 170mm polisher. Came with 3 mops,white,red and blue. i gotta tube of g3 regular grade cutting compound...nowt else
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Slide the G3 to the back of the cupboard mate, its a heavy cutting compound. Halfords stock Meguair's Ultimate Compound which is a pretty good light to medium cutting polish and will work ok. The pads that come with it should be soft going through to quite firm sponge?
    Remember you'll be using a Rotary which is a lot less forgiving than a DA polisher. Read this HERE
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Much appreciated..is the Meguairs not available anywhere else?..ie cheaper than Halfrauds..
  1. da polishing
    By vinty firth in forum Northern Ireland (RO - Vacant)
    Last Post: 26th July 2012, 11:15
  2. Polishing -How often?
    By Spider101 in forum Detailing and Car Care Discussion
    Last Post: 14th April 2009, 19:19
  3. Complete Amateur Polishing/Waxing Advice.
    By BigMan in forum Detailing and Car Care Discussion
    Last Post: 3rd August 2007, 15:03
  4. Polishing advice
    By Matty H in forum Detailing and Car Care Discussion
    Last Post: 10th November 2006, 00:12
  5. Polishing day
    By grumpano in forum Quick Photo Album
    Last Post: 10th May 2006, 16:24
