Thread: 1.9cdti clutch and flywheel change
    Regular Member danny_n's Avatar
    Feb 2011
    wakefield
    Default 1.9cdti clutch and flywheel change
    i need some advice please, i'm having the clutch and flywheel changed next week but i am supplying the parts to keep costs down. i currently have the following;
    clutch including slave cylinder-http://www.eurocarparts.com/ecp/c/Va...84ec3ebe3&CLUK
    flywheel-http://www.eurocarparts.com/ecp/c/Va...32ad520c6&DMFW
    is there anything else i need? i'm sure i've read something about flywheel bolts and clutch fluid?
    any help appreciated
    West
    So far your parts are £550 + clutch/brake fluid... what about gear box oil.
    & just out of interest how much are you paying for the labour?
    the reason i ask is i had my dmf etc changed recently for £600 all in from a clutch specialist in west yorks... both dmf & clutch were LUK items
    Feb 2011
    wakefield
    i got the parts for £380 with the 30% discount code. i've had a quote for £250 for the labour, i just need to know what other parts i need. i was under the impression that the gearbox oil wasn't drained during this process? i could be wrong though.
    which clutch specialist did you use out of interest?
    West
    The gear oil is drained & some garages just strain the oil & re use... mine was replaced with 2.4litres of new.
    I used Topgear Transmissions in Cleckheaton, another member had his done on the same day, while he was dowwn here from Scotland.
    Feb 2011
    wakefield
    thanks, i'll have to give them a ring it seems like you got a good deal. i didnt realise about the gear oil. i only changed it all a month a go so hopefully it can be reused.
    don't suppose you know whether the flywheel bolts had to be changed?
  1. clutch kit and flywheel
    By coooky in forum Engine & Drivetrain
    Last Post: 22nd June 2011, 18:17
  2. 1.9CDTI 150 clutch / flywheel issue
    By LGD in forum Engine & Drivetrain
    Last Post: 28th January 2011, 00:29
  3. New flywheel and clutch :(
    By vectraboyy in forum Vectra C / Signum Car Chat
    Last Post: 10th June 2010, 16:20
  4. Flywheel and clutch kit!
    By fizler316 in forum Vectra C / Signum Car Chat
    Last Post: 7th May 2010, 23:11
  5. gen clutch dm flywheel
    By vecdti in forum Parts for sale
    Last Post: 9th November 2008, 22:02
vectra c 1.9 cdti clutch flywheel
vectra c 1.9 cdti flywheel
vectra cdti flywheel change
how to replace clutch vectra 1.9
