Hi Guys and Gals,
I'm a new to the forum but not to vauxhalls, I have a Zafira GSi running 298bhp and 328lbft.
I have just bought a 2003 GSi auto with 76k, full stealer, history full leather,sat nav, sunroof 314mm front brakes and a few other mods, to run to work in.
Now the problem is the car has run fine for the past 3 weeks till Monday, started it up first thing and it won't idle. After a few tries it did fire up but misses very badly and both T/C light, spanner on digital display and emmisions light are on. The car would only select 5th gear unless using + or - and then you can only get 2nd and I was shocked to find the brake pedal is rock hard too. So I took it to my local dealer and got it Tech-2'ed. The codes came back as P1700, P0700, P1895 which are for the gearbox, B69 Air mass meter and A84 engine ECU!! They said a new air mass meter and gearbox service should fix it, so £650 later and it was ok.
Now today the same has happened again. Has anybody had the same problems?? I'm going to take it back to the stealers tomorrom to find out why its not very happy. Any info would be great. Its been a great 3 weeks driving it, its a great car, so would like it back to it normal happy self.
