Thread: DAB Aerial thread size?
    Oct 2010
    Lincoln
    Default DAB Aerial thread size?
    Anyone know what the thread size is for the DAB aerial on a Vectra C?
    Seems they come in M5 or M6 but I am led to believe that this one could be M7?
    Was going to get one from Halfords but they were all sealed so couldn't try one
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    I am sure its M7 never found an aftermarket one that fits mine so gave up if you find a make that works give me a shout.
    Dec 2011
    Woking
    Trim : Exclusive
    Engine : 1.8vvt (Z18XER)
    Mileage : 58000
    The Vectra DAB aerail fitting for the mast is female 7M thread. I got an aerial from Bulgaria with the 7mm adaptor. Also the fitting is different from the standard base so the splayed rubber bottom of the mast will not sit properly - you have to trim it with a knife and file to smooth out so it sits inside the base. Looks and works fine but you have to do some work to get it to fit.
    http://myworld.ebay.co.uk/the_truck_...84.m1439.l2754
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    Oct 2010
    Lincoln
    Sadly that doesn't look like a DAB aerial. These have a twisted metal section at the bottom under the plastic. Unless someone knows different?
    Mileage : 000
    DAB arial thread is M7.
  1. Tyre Size change - Yep, yet another thread about this!
    By coldo in forum Vectra C / Signum Car Chat
    Last Post: 19th October 2012, 12:32
  2. Wheel size and tyre size
    By DSmiddy in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2011, 19:19
  3. Vauxhall Aerial 7mm thread
    By leeds vectra in forum Parts for sale
    Last Post: 8th January 2010, 18:49
  4. what size thread
    By Dwabo in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2008, 02:23
m7 aerial dab
05 vectra estate aerial size
dab aerial on a 2005 vauxhall vectra design
vectra c dab aerial
