Thread: jailbroke iphone on 3
    Regular Member coooky's Avatar
    May 2011
    washington
    Default jailbroke iphone on 3
    quick question will a jailbroke iphone 3g work on the 3 network ??
    cheers
    VIP-Member puppet's Avatar
    East Ayrshire
    10 Post(s)
    Vehicle : Insignia 1.8 SRi
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    Jailbreaking is not the same as unlocking, so the short answer to that is no.
    If you want to unlock the phone to work on another network (assuming it is currently locked to O2 etc?) then you will first have to Jailbreak, then unlock using something like UltraSnOw.
    Have a read at this, it might help: http://www.iclarified.com/entry/index.php?enid=4253
    (If you fancy having a go at it, note that you have to be on a certain baseband for UltraSnOw to work.)
    May 2011
    washington
    ok the listing says
    Apple iPhone 3 G (8GB) Unlocked & jail broken
    East Ayrshire
    10 Post(s)
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    Could mean one of two things I reckon.
    Either:
    a) The handset has been properly unlocked by the carrier at the end of the previous owners contract, or
    b) It's been jailbroken and then unlocked using a method similar to the one I linked to above.
    A "proper" unlock by the carrier would be far better to be honest. The jailbreak/unlock route does work ok, but each time a new firmware is released you have to wait on a suitable unlock method becoming available before you can upgrade your handset. Every time you update the firmware the handset loses the Jailbreak and is "relocked". It then needs Jailbroken and unlocked again. With a proper unlock you don't have this carry on.
    I used to have an iPhone 3G, and it ran slow as a 3 legged donkey on the newer versions of firmware (iOS4). To be honest, unless you are getting the 3G for a steal, I don't know I'd bother. There are strong rumours that the iPhone 5 / iPhone 4S is due in September, so the prices of the faster 3GS's should hopefully drop a bit then, and one of then would be a better bet than the 3G if you are just looking for a cheapy iPhone.
    Just a thought....
  1. iphone 4
    By kns in forum General Chat
    Last Post: 14th July 2011, 17:44
  2. iPhone App
    By spennny in forum The 'Off Topic' room
    Last Post: 14th June 2011, 21:06
  3. iPhone
    By WeDesign in forum General Chat
    Last Post: 28th March 2010, 12:54
  4. Anyone with an iPhone??
    By Adz86 in forum The 'Off Topic' room
    Last Post: 29th October 2009, 21:04
