Thread: Vectra c 2.0 DTI 02 EGR will not budge!
    Jun 2011
    YORK
    Default Vectra c 2.0 DTI 02 EGR will not budge!
    I cannot get the EGR out to clean is there an easy way of doing this?
    Im pulling my hair out and my back is shot!!
    Please help ;(
    Regular Member Innes's Avatar
    Plymouth
    They are a ****** to shift. It took me 10 mins of tapping with a rubber mallet and also some gentle taps with a hammer and a blunt chisell about 1cm away from the join working left and right. It will go eventually.
    Patience is the key!
    Regular Member Vectra Forever's Avatar
    Apr 2011
    Somerset
    Perseverance is all I can say and some brute force. Keep at it and it will come out. If the block is cold then it will be harder to get out. I killed mine when trying to get it out as can be seen. Make sure the block is warm, both bolts are out and spray some WD40 or Pen oil on the flange then pull backwards and try to turn / twist the valve and it should pop out.
    I tried everything and in the very end resorted to a half inch wood chisel to get it out. When it did come out the aluminium on the inside of the flange and the open bore was corroded which is why it was so hard to get out. Obviously with all the banging and knocking etc I broke the coolant outflow pipe, right flange and the rear control module fell off too. So I had to spend £226 for a new valve. Just be careful and don’t go stupid on it and you should be ok.
    Jun 2011
    YORK
    Jun 2011
    YORK
    Is it best to go with the chisel at the part in red or at the sides?
    Also would I be able to lever it out where the part in yellow is.
    Thanks for your help
    Plymouth
    I tapped on all three edges. You're not trying to get the chisel in a gap but put shock waves through the metal to loosen it. Firm taps but don't go belting it!! Stop every sof often and give it a twist and wiggle.
    It can be done!!!
    Jun 2011
    YORK
    cheers. will try again today.
    Regular Member bulletproofpanda's Avatar
    Sep 2010
    Nottingham
    I also put some WD40 on the casing when I put it back in to stop the problem for getting it out in the future. I went with the wiggle and shout option!
    Jun 2011
    YORK
    HI, finally got it off and yes the best bit of advice is make sure the engine is warm. It took only a couple of taps and it came straight off. Thanks everyone especially Vectra forever.
  1. oil filter wont budge!
    By djlee in forum Engine & Drivetrain
    Last Post: 3rd March 2012, 16:09
  2. odd staining on front headlight lens that wont budge?
    By richiem in forum Vectra C / Signum Car Chat
    Last Post: 11th April 2011, 20:17
  3. Help..indicators wont budge!
    By Dwabo in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2008, 20:12
  4. Advice please!!: Irmy tyre valve caps will not budge!!
    By RSV_Ecosse in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2007, 18:06
  5. Brakes - how do the discs budge?
    By johnmac in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2007, 04:10
