Thread: bad joints on pcb
    slough
    Default bad joints on pcb
    a little while ago someone showed some pics on here of a badly solderd printed circut board where on the vectra c was this board anyone know ?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Throttle body of a 2004/05 1.9 CDTI.
    slough
    yeah thats the one where is that pcb
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by hippo View Post
    in the bottom of the tb, inside the black base.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Just done mine Sunday, The circuit board has seven solder spots all together and i cleaned mine with elec contact spray & a fine brush, With a strong magnifying glass they looked in perfect condition but there must have been a problem with one or more of them, I was getting the car/spanner light but no other symptoms as such only some times with reduced power/limp home, The code stored was P1125 - Throttle Actuator Malfunction (61) - Not present, But if the engine management light also appears it maybe 'present', Then you may have a full limp home mode job, The only solution is to clean the body & flap spotless then do a re-solder of the joints as per the 'how 2', I found doing it easy 'under a magnifying glass' with the help of an assistant holding the glass whilst re-soldering, The joints are 'small' but look a 'lot' bigger in the 'how 2' guide, Just a gentle touch of each solder then when melting starts just add a ''small amount'' of new solder & jobs a good un!.
    http://www.vectra-c.com/forum/showthread.php?t=119346
    slough
    cheers guy`s which how 2 is the exact one and where under the bonnet is this black box please....
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    The throttle body fix for the CDTI 150. The black box is the base of the throttle body - so when you remove the throttle body, it's base is black - where the electrical connection is plugged in. The base is held on with 5 clips. Watch the clips though as they fly off when you release them.
    slough
    any pics ?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    any pics ?
    http://www.vectra-c.com/forum/showthread.php?t=136699
  1. Inner CV Joints
    By Gmc12 in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2013, 17:22
  2. CV Joints / Driveshaft
    By VXR_DV in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2011, 21:11
  3. Inner Tie Rod Joints
    By Electricdave in forum Suspension, Wheels & Brakes
    Last Post: 8th June 2010, 19:29
  4. cv joints compatability
    By dan the man in forum Suspension, Wheels & Brakes
    Last Post: 21st July 2009, 21:09
  5. Ball Joints
    By xaviroller in forum Suspension, Wheels & Brakes
    Last Post: 26th June 2009, 20:10
