Thread: Do i have manifold flaps ?????
    Regular Member rockonoli1's Avatar
    Telford
    Default Do i have manifold flaps ?????
    Good evening boys and girls, i have a 1.9cdti 120 bhp siggy with the following fault code P1901 i have had it on my snap on scanner and it says excessive differential pressure tried no end of times to do a regen went all the way on holiday a couple of weeks ago (120 mile) to campsite in 3rd gear light didnt go out until a stop start (strange i thought). Then on the way home a week later the light came on again with the same fault code, i was thinking along the lines of the pressure sensor but i have asked a VX tech, as i am a skoda tech what his thoughts are and he said the manifold flap will cause this fault, but i was under the impression that onl the 150's had this problem? am i right or wrong i don't know?
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    No you don't
    Breath a sigh of relief.
    Insignia VX-Line Nav CDTI 170.
    West
    sounds to me like the dpf is blocked & may need more than just a regen
    Telford
    i've had the dpf soot accumulation checked and that was only 14% so it cant be blocked but i am glad i dont have the flaps, i thinks its time for a remap,
    Oh i forgot to mention i above post i have a tuning box would that cause problems ? i know i am about to get slaughtered but hey ho
    West
    the tuning box could be the clogging of your dpf, the only way to tell for sure is remove the dpf & flush it clean
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    alls i would say is remove the box and try do the regen again, and see how it goes for a week without m8
    Telford
    will remove and try cheers neill
  1. Inlet Manifold - Swirl Flaps?
    By Elahi_786 in forum Engine & Drivetrain
    Last Post: 5th April 2011, 23:38
  2. loose manifold flaps
    By luke.oldham in forum Engine & Drivetrain
    Last Post: 21st April 2010, 09:44
  3. swirl flaps/manifold DIY replacement
    By dth150 in forum Engine & Drivetrain
    Last Post: 26th June 2009, 15:36
  4. swirl flaps intake manifold
    By galway1 in forum Engine & Drivetrain
    Last Post: 6th May 2009, 21:40
