Thread: Wheel Vibration Under Braking
    Wondering lonely as a cloud
    24 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Default Wheel Vibration Under Braking
    I have just fitted second hand 314's and from the off they have vibrated when I brake, I had 302's on before and they didn't however to add more confusion I had my wheels refurbished and they are very tight to get on and off.
    My thoughts are the second hand discs are slightly warped as I know the hub nuts are tight and its just had an MOT so the suspension is tight, or the powder coating that makes the wheels tight is making the wheels run slightly out of true, however the vibration is only when I brake.
    Anyone have any suggestions please
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    deffo sounds like warped disk's to me, can you feel the brake pedal sort of bounce when braking..
    Midlands Mod Shop - NFFC.
    Second hand brakes, I would start there
    Presumably the pads and discs are second hand
    The 314mm discs are known for vibrations, I've had it twice now
    Ideally perform lots of full service brake applications, rather than light ones
    Once you have performed about 20 take a look at the discs
    If there is a ring around the inner edge then there is nothing to worry about, this is just the surfaces coming together and eventually they will match, the ring will then disappear
    I get this with roughly every fifth or sixth pad change on used discs, it typically happens on the second set of pads on the discs
    Nextly have you had the brake bias checked and adjusted?
    If the rear brakes are the same, then it will need to be adjusted towards the rear
    24 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    I was going to get new discs but if this vibration is common there doesn't seem much point I'll try the heavy braking and see, the brakes are solid but they are second hand pads and discs but I have done 300 miles on them so far
    The rears are new 292's but everything there seems fine no rings just clean discs, forgot to add that the discs were rusted when I got them and they are now clean after about 150 miles of use.
    As the rears are 292, then you don't need to change the brake bias, the difference is negligible
    As above, perform several heavy braking applications then inspect the discs and post again
    It usually takes about 2000 miles / 4 weeks for the pads and discs surfaces to match up and wear down evenly
    Surface rust on discs is common, mine even have this after leaving the car overnight!
    Nextly, presumably you swapped the calipers from 302mm to 314mm
    What condition were these replacement calipers and pistons?
    I only ever fit new calipers, I wouldn't touch a used one, even if it was free, unless it was refurbished/tested/overhauled
    24 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    I fitted second hand ones but they were in very good condition had them apart and replaced the seals and they are solid and don't pull to one side passed the MOT 2 weeks ago and were fine apart for a comment about the rust.
    I have just been out and about with the car and did as you suggested about 20 full hard brakes to a standstill from 40 and strangely the vibration isn't there under heavy braking only if the are gently applied for normal slowing down.
    I looked for a ring around the inner part of the disc and there is a small band so maybe they just need to fully bed in.
    New Member melvyn8181's Avatar
    Jul 2011
    north lincolnshire
    i had same problem, so i got my wheels balanced and then it was cured.
    24 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Strange you should say that had mine rebalanced today and its mostly gone, also M8Internet I did the heavy braking which left a dark ring around the inside of the disc and it was continuous which pretty much rules out warped discs I hope
    Quote Originally Posted by paulhb View Post
    This is quite normal for used discs and used pads
    Eventually the ring will disappear as the surfaces wear and match up flat with each other
    I was worried the first time, suspecting a binding caliper, but was advised to monitor it weekly and if it had not disappeared after four weeks to bring them back, there was no need as I had covered 1000 miles and although it started to get worse it very quickly disappeared
  1. New brakes all around and still vibration under braking!!!
    By Celes in forum Suspension, Wheels & Brakes
    Last Post: 31st July 2011, 14:34
  2. steering wheel shaking when braking
    By n8sby in forum Suspension, Wheels & Brakes
    Last Post: 12th May 2011, 16:22
  3. wheel wobble when braking
    By keith_johnson1967 in forum Suspension, Wheels & Brakes
    Last Post: 16th January 2011, 12:55
  4. wheel Vibration
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2010, 21:56
  5. Wheel vibration at over 70+
    By simonturner1975 in forum Suspension, Wheels & Brakes
    Last Post: 6th March 2010, 11:22
vauxhall vectra c vibration when slowing down
vectra c shaking when braking www.vectra-c.com
vectra c braking shake
