Results 1 to 2 of 2
Thread: Help...hesitation, juddering at low revs
    birmingham
    Default Help...hesitation, juddering at low revs
    Hi, been searching through the forum for symptoms like mine but getting frustrated as the car worsens and I've not yet found the problem. Car gives a shudder when cruising or easing off the acceleration, mostly between 1500 to 2000 rpm. It is happening more and more frequently now but still clears if I put my foot down. I'd be fine if I was flooring it everywhere! Have changed the fuel filter and used diesel additives. Had the EGR off and cleaned this, have had the thermostat replaced, cleaned the boost sensor. It seems to be using more fuel too. What would you reckon as the next thing to check, throttle body, injector 3 wiring???? Any other suggestions? Thanks
    chesire
    sounds like the egr is sticking on opening or closeing to me. try unplugging it and take it round the block to see if it still jerks
  1. Replies: 0
    Last Post: 3rd February 2013, 13:54
  2. 2.0T Hesitation
    By GoldenWonder in forum Engine & Drivetrain
    Last Post: 8th May 2012, 12:48
  3. Hesitation please help??
    By sowter28 in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2010, 17:43
  4. hesitation
    By aledjones_lex in forum Engine & Drivetrain
    Last Post: 1st April 2010, 18:44
  5. hesitation
    By pogo in forum Engine & Drivetrain
    Last Post: 26th March 2006, 21:06
