Thread: fault codes help needed please
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    Default fault codes help needed please
    got an old vectra with over 1000k on it, eml has come on and refuses to go away,got three codes out using the pedals thanks to info from the forum,they are 0153,bank 1 sensor 1 voltage high or low or an open heater circuit, 0110 intake air temp circuit high input or low input c-12 and 0100 mass or volume air flow circuit high or low input c-10,trouble is i dont understand a word of it could someone explain in idiots language for me please,and could one be causing the others,cheers.
    Jun 2011
    Elland
    Bad connections / failed sensors on the mass air flow (MAF) and inlet air temperature sensor?
    Jun 2011
    Vehicle : vectra
    Year : .....
    thanks for taking the time to offer some advice hebble, spent the afternoon wrestling with the beast, cleaned all connections and throttle body,then found broken insulation on two lambder wires grey and white touching sorted that cleared codes,and up to now no light and no codes,fingers crossed.
    Jun 2011
    Elland
    Good Job!!!!!
  1. Quick help needed reading fault codes!
    By Veccy55 in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2013, 17:08
  2. help needed to fault find (or read codes) 2.0DTi
    By FLOB in forum South East (ARO jaqubek)
    Last Post: 4th April 2012, 18:15
  3. Getting 2 fault codes come up
    By Lozza in forum Electrical & ICE (including SatNav)
    Last Post: 7th June 2011, 16:17
  4. how to determine parts from fault codes... help needed.
    By tan786 in forum Engine & Drivetrain
    Last Post: 25th June 2010, 18:13
  5. Help needed / fault codes??????????????????
    By muniman_gsi in forum Engine & Drivetrain
    Last Post: 5th April 2010, 09:30
