Thread: Flip Key (3 Button Type)
    Aug 2010
    Stoke on Trent
    Default Flip Key (3 Button Type)
    This...
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWNX:IT
    ...plus...
    ...plus 2 minutes programming and voila... a 3 button flip key for my preface Vec C.... at £35... a fraction of the stealers cost
    Regular Member BYGino's Avatar
    Jun 2011
    Lanarkshire, Scotland
    I saw that combo too, I need a second key for the new car. I need a 2 button one though like this one
    http://cgi.ebay.co.uk/Vauxhall-2-But...item1c1d0b7ed7
    Can you programme the car to accept the key though yourself, i thought it was a dealer only job and they charge about as much for doing that as they do the key.
    Aug 2010
    Stoke on Trent
    Quote Originally Posted by BYGino View Post
    If you own a genuine copy of Vaux-Com, Op-Com or Tech 2 then yes you can... I wouldn't attempt it with anything else. However an independent garage may charge as little as £30 to £40 for a Tech 2 session so it still works out cheaper than dealers.
    Regular Member coooky's Avatar
    May 2011
    washington
    mine is like this one
    http://cgi.ebay.co.uk/VAUXHALL-VECTR...12158846918663
    can i change it to the flip key if yes where do i get the H code from and how do you programme the fob ?
    cheers
    May 2011
    washington
    found this on wiki is it correct though ??
    You turn the key to the ll position or second click and press the remote pad to open the car. The central locking and indicators for the immobiliser should activate and that is the key programmed. Hope this helps.
    Jun 2011
    Can anyone get an op-com or vaux-com?
    Aug 2010
    Stoke on Trent
    Quote Originally Posted by coooky View Post
    cheers
    Yes you can as this is exactly what I did.... your H code will be on your car pass.... the fob is programmed using a genuine copy of Vaux-Com, Op-Com or Tech 2.
    no... this will re-sync a key after a battery change and will not program a new key to the car.
    yep... http://www.ilexa.co.uk/
    Jun 2011
    Cheers for the info Jimbo, some good reading there.
    May 2011
    washington
    Quote Originally Posted by jimbojetset View Post
    Yes you can as this is exactly what I did.... your H code will be on your car pass/[/url]
    i dont have a car pass never got any paperwork with the car
    Full Member
    Bristol
    You will have to take your logbook to the stealers and they will order you a new card for about £20 once paid they will give you a print out until your card comes.
  1. 3 button non flip key internals fit straight into a flip key shell???
    By Jow20 in forum Electrical & ICE (including SatNav)
    Last Post: 25th November 2011, 01:44
  2. 3 button flip key
    By bembo449 in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2011, 18:54
  3. 3 & 2 Button Flip KEY
    By 3.2wales in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2011, 05:58
