Thread: Noob with a 2005 2.2 SRI Vectra
    Jul 2011
    Elgin, Scotland
    Default Noob with a 2005 2.2 SRI Vectra
    Hi
    My name's Phil and I've recently bought a 2005 plate Vectra 2.2 SRI in silver as a bit of a project!
    List of problems:
    Timing Chain Snapped/Possible Tensioner
    Broken front Coil Spring
    Rear brake pipe over tank heavily corroded
    ABS Light on
    Battery Light on
    Brake Light Switch Warning on
    So far I've resolved the timing chain issue, it had slipped due to a bolt on one of the guides working loose! A full new chain kit from Autovaux and she fired up perfectly
    Changed the coil spring for a genuine Vauxhall SRI lowered spring.
    Changed the brake pipe that runs beside the fuel tank (not fun)
    Resolved the ABS light with a dodgy connector on the N/S/F and re-wired from the sensor to the multiplug under the car on the N/S/R sensor!
    She absolutely flew her MOT with this done so happy days!
    I only have the Battery Light and Brake Light switch warning to resolve!
    Oct 2006
    southampton
    15 Post(s)
    Quote Originally Posted by calibra_se8 View Post
    Hi
    List of problems:
    ABS Light on
    Battery Light on
    Welcome along matey, broken springs are common on the vectra, most go for aftermarket lkike Eibach, they never snap, check the alternator for the battery light, alternator is another common fault.. also, go to a dealer and get the fuel pressure regulator checked, its on recall so wont cost and get handbrake recall done at the same time matey... HTH
    Full Member spennny's Avatar
    Blantyre
    Welcome mate
    Brake light switch is a 10 min job, most prob its been not set correctly, should set you back about £10 from the dealers
    Its easier to snap the old one out and just push the new one in and let the brake pedal up slowly
    Jul 2011
    Elgin, Scotland
    Cheers mate, I've changed at least 7 or 8 springs on different C's and Signums, I've usually found the front springs break due to the crappy strut top mountings! I want to keep this one original, it handles great as it is and the spring was under £50 with the trade discount at the stealers so not all bad!
    I actually owned another 2.2 a wee while back now
    Thanks for the advice on the laternator but I fear me jump starting the car may have done some damage ratrher than the alternator, although I'm hoping the brake light switch problem is related.
    VOTING UKIP IN AVELEY
    18 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    welcome to Vec-c ..........your doing really well on the repairs ...
    Jul 2011
    Elgin, Scotland
    Quote Originally Posted by spennny View Post
    Welcome mate
    Thanks, much appreciated, I'm not 100% the switch is at fault though. I reset the fault code with Opcom and then the brake lights work with no warning for a few pumps of the pedal, then the warning comes back again and the brake lights stop working, reset it again and again and same procedure every time, strange
  1. For Sale: Vectra C 1.8 2005
    By mattster87 in forum Cars for sale
    Last Post: 8th February 2012, 15:26
  2. My 2005 Vectra SRi
    By rob10 in forum Quick Photo Album
    Last Post: 25th February 2011, 16:28
  3. Newbie Noob, Vectra 150 Nav
    By Barker.Vectra.Sri in forum Introduce yourself.
    Last Post: 17th December 2009, 01:55
  4. 2005 Vectra 2.2 SRi
    By bertxuk in forum Cars for sale
    Last Post: 3rd March 2009, 22:02
  5. Ditching CDR 2005 - Noob questions
    By AirCooledHeaven in forum Electrical & ICE (including SatNav)
    Last Post: 8th December 2007, 21:18
