Thread: Central Locking
    Jul 2006
    Default Central Locking
    Sorry all, this is an astra-related question but i'm hoping any nice peeps who work at or with Vx might be able to help!
    05 plate Astra Design, 1.9 CDTi, passenger side rear door does not lock with central locking. This model doesn't have door pins, so I can't check manually. Is it likely to be as simple as a faulty servo or fuse, and if not, anyone got any ideas?
    Could well be a servo motor fault.. also check the security of the harness connection where it enters the door.. are any other door operations Electric window etc affected??
    Nicking Ya Dinner.
    Motor, has anyone slamed the door recently, kills em.
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    isnt the car under warranty?
    Regular Member benny's Avatar
    Feb 2006
    dudley
    the wiring loom conector in the door has come adrift ....look down at the hinge area you will find it there take it back under warantee .......if you wana lock the door you can by> open the door look at the latch area on the door just to the left of the latch there is a oval hole put you key into this hole and push (inwards)till you hear a click ..the door is now locked ....all you need to do to open is pull the door handle inside but make shure the child lock is of other wise you wont open the door again hope this helps benny
    Feb 2006
    Dorset
    if its the one in yer picture , it might be traumatised after the wheel incident ......
  1. Central locking
    By stevie16v in forum Bodywork & Interior
    Last Post: 21st March 2011, 18:56
  2. Central Locking
    By Exclusive BV in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2011, 22:27
  3. Central locking
    Last Post: 13th October 2009, 19:16
  4. central locking help !!!!!!!
    By VECKSZ in forum Electrical & ICE (including SatNav)
    Last Post: 14th April 2009, 17:37
  5. Central Locking
    By S14RRJ in forum Electrical & ICE (including SatNav)
    Last Post: 2nd April 2008, 01:04
