Thread: Changed rear coils, check the pics !
    Jun 2011
    Fife
    Default Changed rear coils, check the pics !
    When i got thiscar i noticed at last service it advised of a cracked rear spring. I jack it up and cant see crack but do spot one side is different to the other ...i put this down to perhaps its lost a coil! Anyway i dont believe in just doing the advised side so bought two coils and fitted them tonight...look at pics of springs...both fitted at different garages ..one claimed to specialise in top end cars and servicing etc the other was kwik fit !!!
    Two different shaped springs, different thicknesses etc ...i just cant believe a garage would put this type of work out !!!
    north east
    Odds on bet finish the song ...
    you cant get thicker than .....
    Jul 2010
    Warrington / Liverpool
    ... A kwikfit fitter?
    I was going to say one is an aftermarket spring but it looks like it may be a completely wrong spring lol
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    your right cos the one on the left is a progessive coil spring and i cant believe any fitter even a kwick fit muppet would miss that
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    as I say..if you can DIY then your best off doing it yourself..at the least you know its rite and it helps the bonding process.A bita tlc never hurt no one.
    Jun 2011
    Fife
    i agree with the DIY thing, i am reading more and more posts of people attempting jobs they wouldnt have touched previously, you do know its done right and it gives great satisfaction !
    I am going to Holland on Thursday in the Vectra and glad i done this, i would probably have got away with leaving them until i was back but it would have been a PITA always wondering if it was going to make it !!
    newport
    i'd rather let my 8 year old try and fix the car than kwik fit
    Jul 2011
    ISLE OF MAN
    Default For Info
    What is the correct spring length and number of coils please?
    I looked in the KYB pdf catalog for their K-FLEX springs and they say that their number is RX6217 for a 1.9 CDTI ESTATE but when the springs arrive I would like to be able to check them, the full spec would be ideal but the the above info would be a good guide.
  1. fuel filter changed, cleaned + few mods (pics)
    By Big Red in forum Diesel Engine related
    Last Post: 4th August 2012, 13:06
  2. check these egr valve pics out! Seems i have a missing part!
    By richiem in forum Engine & Drivetrain
    Last Post: 20th September 2010, 19:07
  3. should dealer have changed my rear discs/pads
    By mitch in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2010, 18:28
  4. Rear Brake Pads - Changed design or just the wrong ones?
    By Angelchops in forum Suspension, Wheels & Brakes
    Last Post: 25th September 2009, 09:38
  5. Changed the rear suspension arms yesterday
    By monkeez in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2009, 12:07
