Results 1 to 10 of 11
Thread: hello any1 help with noise coming from rear wheels
    May 2011
    AYLESBURY
    Default hello any1 help with noise coming from rear wheels
    when i go over bumps,even the smallest bumps i can hear rattling metal noise from rear wheels. had my rear brake pads and caliper changed ,still not sorted!its so annoying,its strange cos when i apply my brakes lightly while driving over bumps ,sound goes away.then i tried my handbrakes pulled up 5/6 clicks when driving ,sound not there!!!!
    so any 1 ,can u please give some help with this,dont know whats wrong????
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    are the pads in the right way round? one side has lugs on so it fits in to the piston
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    thats what it sounds like to me as well mark
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by markj23 View Post
    Jul 2011
    Birmingham
    Might be completely wrong, but I had a similar problem which got far more noticable at 70+mph.
    I got underneath the car and found the heat shield around centre box was hanging. The nuts/spiggots rust and snap off really easily, I've managed to cable tie mine into place for now. I'm a little stuck as far as to fix it permenantly!
    Jul 2011
    Elgin, Scotland
    I would be checking your exhaust heat shields also.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by awilson1234 View Post
    Same happened to me. Where the nut goes on, had broken away on the heat shield, so I removed the nut and put a large washer on (first pic). On the front one, the spiggot snapped off. If you remove the spare wheel, you will see where it was attached to. Insert a bolt through from inside the car, and a washer/bolt underneath (second pic). Hope this helps
    It is now solid and secure, and does not rattle at all
    Jul 2011
    Birmingham
    Mines not rattles for a couple of months now, so I'm not going to fix a problem which doesn't currently exist (I got enought that do!!)
    Thanks for that though, well worth knowing!
    May 2011
    AYLESBURY
    hey thanx guys for all reply
    yes mate think its right way round ,had both replaced buy some1 that i always get 2 do my car.he thinks it mite be the hand brake lever that needs changing cos its not pulling the cable tight enough.so what do u guys think?doesnt sound like any thing under the car!!
    newport
    does the vectra c have anti rattle springs on the rear pads? when i had a cav i lost one and would make a really bad rattling noise until i touched the brakes
  1. Noise coming from the rear
    By msqualo in forum Electrical & ICE (including SatNav)
    Last Post: 29th November 2011, 18:16
  2. grinding noise coming from rear wheels
    By pud wayman in forum Suspension, Wheels & Brakes
    Last Post: 21st June 2011, 07:27
  3. knocking noise from rear wheels
    By melvin in forum Suspension, Wheels & Brakes
    Last Post: 20th June 2011, 14:47
  4. Strange grinding noise coming from rear wheel
    By sproket in forum Suspension, Wheels & Brakes
    Last Post: 27th May 2009, 22:04
  5. Loud bang coming from the rear wheels/suspension
    By SNODDY70 in forum Suspension, Wheels & Brakes
    Last Post: 22nd February 2009, 00:53
metallic rattle noise coming from rear of my vectra
