Results 1 to 10 of 11
Thread: Engine coolant
    Aug 2010
    London
    Default Engine coolant
    I have started to notice that my temperature gauge does not increase while I am driving. I drive long distances on motorway and temp still does not move. It only moves when in traffic, it will move to the middle and stay there but decrease to 0 once moving again.
    My car is a 2003 vectra c 1.8 16v LS
    I suspect i will need to replace thermostat which will mean removing thermostat housing.
    What is the best coolant to refill the car with? It is currently blue at the moment.
    Ps any help or information about thermostats please let me know.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Quote Originally Posted by Tank988 View Post
    It shouldnt be. If it is change it ASAP. All engines in the Vec range require the orange/red OAT coolant, it is long life and has anti corrosion properties as well as lubricating the water pump properly. Someone has changed it for the blue stuff which is only marginally cheaper than the correct OAT coolant.
    BTW yes you are correct in thinking the thermostat is knackered, easy and cheap to replace though, i'll get you the how2 for it
    Regular Member puppet's Avatar
    East Ayrshire
    10 Post(s)
    Vehicle : Insignia 1.8 SRi
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    http://www.vectra-c.com/forum/showth...ght=thermostat
    Have a look at that matey, should help.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Z18XE Thermostat Change
    Opie Oils Explains Antifreeze
    VX Antifreeze is actually as cheap as you will find it at any motor factors btw.
    Glasgow
    As above thermostat required and get the blue coolant out ASAP.
    Aug 2010
    London
    Thanks Das Arab for your reply
    I did a test today to see if i could check. I squeezed each of the water pipes when engine off and when squeezed I could feel the water passing through and in the tank.
    Thanks for your info on the coolant, i have no idea what the differences in coolant were. I will definitely replace with the pink stuff. Had a look on halfords:-
    Either this:
    http://www.halfords.com/webapp/wcs/s...Id_229902#dtab
    or the already mixed one:
    http://www.halfords.com/webapp/wcs/s...k&iozone=PDPz1
    What would you recommend for me.
    Any how2 guides would be fantastic buddy as i have never done this procedure before.
    (Hope that crap ant done any damage to the water pump or hoses then)
    Aug 2010
    London
    Thanks guys for your reply's.
    I am looking into the Halfords stuff listed above. Anyone got any recommendations?
    Thanks for the how2 guide. A wee question. I am planing on buying the thermostat on its own if possible without the housing. In doing this can I just reuse the the old gasket (after cleaning the areas). Will any sealant be required as i was not planning on using any?
    Is it cheaper to buy from VX instead ??
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Check with your local VX dealer, sure its only around £18 for 5Lt of the concentrated stuff. you need to achieve a protection of -28 so id avoid the ready mixed stuff tbh. Penfold just got a good deal off ebay for his VX Coolant, i'll see if I get a link.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWNX:IT
    You will get away with 3lt btw. Yes if you buy the insert thermostat of ebay you can reuse the original gasket, I did, but you will need some instant gasket seal to seal it.
    Aug 2010
    London
    Ahh thanks for the link. I have added it to my watch list until i check with the Vauxhall dealer to see how much they charge.
    Is this the stuff that would work ok?? I think this is the stuff you used?
    http://www.halfords.com/webapp/wcs/s...Id_165691#dtab
    Do you know much about these newly designed thermostats that when they stick, they only stick open as it is better than closed. Is this common with them all now or do i need to go looking for this type of thermostat?
  1. loosing engine coolant
    By pud wayman in forum Engine & Drivetrain
    Last Post: 25th March 2012, 10:16
  2. loosing engine coolant
    Last Post: 13th March 2012, 09:14
  3. What engine coolant?
    Last Post: 31st May 2009, 23:45
  4. Engine Coolant?
    By jamesr in forum Engine & Drivetrain
    Last Post: 23rd February 2008, 22:07
  5. Engine coolant
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2007, 09:08
vectra c 1.8 coolant replace site:www.vectra-c.com
