Results 1 to 2 of 2
Thread: Fm/dab
    Oct 2010
    Lincoln
    Default Fm/dab
    So how does this work? Gotta a 56 plate Sri which intermittently decides to get either FM or DAB OR both!! FM seems worse then DAB (which is obviously fine when I get it). Could this be the aerial unit on the roof? Only seems to have started since I started to use a car wash which I though needed me to unscrew the aerial is this normal or has doing this affected the DAB unit on the roof?
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Have you cleaned out / dried out the socket into which the whip screws in?
    dirt and moisture, or even corrosion caused by damp, could indeed impair your signal quality.
    But I don't think it would have that much effect, unless the internals have got wet.
