I should mention to my mechanic on wed, gettin oil, filter, gearbox oil and fuel filter changed also a full check over, anything else to change/check?
Pollen filter?
Take it you did the brake fluid change with you changed the calipers?
Coolant...? Meant to last the life of the engine but always worth considering...
Time to upgrade to 5.1 or racing spec fluid then
Forsale sign?
