Results 1 to 10 of 11
Thread: 1.9 Cdti 120 hesitation
    Full Member
    Bristol
    Default 1.9 Cdti 120 hesitation
    I have a 1.9 CDTI SRi 120 here on 05 plate it not the engine that the mainfold gives trouble, When driving it is gutless but no missfire . When stopped, you rev up to 1800 rpm and it misses like a pig. New EGR fitted 6 months ago. Took if off the other day and its was clean as a you could get. Any thoughts ?
    Regular Member mcpitman's Avatar
    May 2011
    Derby
    Trim : Club
    Engine : 1.9 CDTi
    Is the turbo spooling up?
    Regular Member vectra 120's Avatar
    Washington Tyne & Wear
    Same as me m8 new ERG If I have the window down it sounds like I have put my hand over the pipe on a vacuum and lifting it on and off when the revs hit 1800-2500
    Steve
    Full Member
    Bristol
    Quote Originally Posted by vectra 120 View Post
    Steve
    Yes it sound so hollow sounds like A pipe has come off.
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Quote Originally Posted by sb1uk View Post
    Just sorted mine and it is now running better than it has ever done in the 8 months I have owned it. Had similar symptons to yours but not sure exactly what fixed it - but this is what I did. Replaced the EGR, fitted the Fiat type 3 hole EGR gasket, cleaned the boost sensor, and replaced the two small vacuum pipes at the front of the engine. The first thing I would do if I were you would be to disconnect the EGR and try running it without the EGR connected - it wont do any harm but will activate the spanner light to start with and later the Engine Management light. I reset mine but I understand from other members that it will go out itself after you reconnect and have a few starts. Good luck.
    Full Member
    Bristol
    Thanks for that I will try that later. New egr fitted 4 months as is clean now. there is no codes in it. So no harm in trying your way. I will let you know.
    Full Member
    Bristol
    Thanks Alcutler just as you said the vacuum pipes on the front were split just replaced them . Car runs goes like helll and no missfire. Thanks.
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Great - glad you sorted it!
    Regular Member DeJohnny's Avatar
    Jun 2011
    belgium
    Quote Originally Posted by alcutler View Post
    what vacuum pipes are you talking about?
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Quote Originally Posted by DeJohnny View Post
    These pipes -
    http://www.vectra-c.com/forum/showthread.php?t=109454 - you need page 6 for pictures but the whole post makes interesting reading
  1. CDTI Hesitation issues....?
    By johns159 in forum Insignia car chat
    Last Post: 24th August 2011, 23:17
  2. 1.9 CDTI 120 Hesitation Judder.
    By CDTI120SXI in forum Engine & Drivetrain
    Last Post: 8th July 2011, 17:45
  3. 1.9 cdti Hesitation at 2500 rpm
    By alkez100 in forum Engine & Drivetrain
    Last Post: 3rd May 2010, 21:18
  4. 3.0 CDTI Hesitation and EML
    By sb1uk in forum Diesel Engine related
    Last Post: 9th January 2009, 06:03
  5. Cdti Hesitation At 2000 Rpm
    By CRAIG in forum Engine & Drivetrain
    Last Post: 9th October 2006, 13:29
