Thread: Anti Hijack/Heater help???
    Ex Ro - South East SRIDAN's Avatar
    Out in the Estate
    Vehicle : Sri Estate Navi xp2
    Trim : Leather
    Engine : 1.9 + a little extra
    Mileage : 80,000
    Default Anti Hijack/Heater help???
    Hello Guys
    I have a problem using the anti hijack on my 03 sri half canbus.
    A couple of weeks ago I borrowed a BCM from Plasmas 57 vectra in order to set up my new electric rear windows that worked fine apart from then my heater controls didnít work then noticed when I got above 5mph the doors auto locked. What Iím looking for I think is a BCM from a 04 where the anti hijack started to see if that works or I could just get a late BCM and then see if I can find out why the heater didnít work and/or wire it so it will work.
    Can anyone please help??
    Regular Member Robsey's Avatar
    North East Cheshire
    Trim : Energy
    Mileage : 101,000
    Both these items are programmed elsewhere.
    The anti hijack is done via the keyfob - look in the how 2 section, or even in your car's manual
    The heater controls may need to be re-programmed in the BCM, and perhaps in the display.
    Swapping the BCM, may have upset your settings.
    Just get your existing / replacement BCM programmed in to the correct settings.
    To be certain, the replacement BCM should have the same part number and Alpha Code as the one that was originally fitted to your car.
    Admin plasma's Avatar
    On the Forum
    182 Post(s)
    Engine : 150
    Mileage : 74000
    Wondered if you'd post up on this one
    We've actually got this sorted now mate, there was a wiring change on 2004.5 cars in how the heaters are powered and it now looks to the BCM for a command signal
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    North East Cheshire
    Trim : Energy
    Mileage : 101,000
    Ah yes...
    Hence the need to swap between half CAN and full CAN heater panels when changing either the DISplay or BCM.
    Glad it's sorted...
    Yes, I've been away for a while due to having strong links with other forums etc... but I still pop my head in now and again.
    scottish region
    the anti hijack does not work on every vectra c mate
    On the Forum
    182 Post(s)
    Engine : 150
    Mileage : 74000
    correct, but can be made to with a simple change, and robsey the heater control panel is exactly the same between the 03 half can and my 05 full can
    North East Cheshire
    Trim : Energy
    Mileage : 101,000
    Ooooh!!!
    How Strange - well it is all sorted now that's all that matters.
  1. how to use anti-hijack???
    By dannydm1 in forum Electrical & ICE (including SatNav)
    Last Post: 29th September 2013, 13:34
  2. Astra-H auto door locking (anti-hijack?). Anyone help?
    By Vaux-Man-G in forum General Motoring Chat
    Last Post: 24th September 2012, 08:35
  3. Oil tanker hijack..
    By macdad in forum General Chat
    Last Post: 18th November 2008, 02:08
  4. Hotmail Hijack
    By david173 in forum General Chat
    Last Post: 27th June 2008, 22:16
  5. VVOC Hijack
    By AJA in forum 2005
    Last Post: 18th July 2005, 22:02
