Results 1 to 10 of 11
Thread: 1.9CDTi RATTLE ON STARTUP
    Regular Member Si-SRI's Avatar
    Oct 2009
    LINCOLNSHIRE
    Default 1.9CDTi RATTLE ON STARTUP
    When i start my car up from cold in a morning i get a rattle from the engine for 2-3 seconds then it goes....its as though theres not enough oil there...oil light goes out straight away and doesn't flicker...its only done 32000miles from new,
    Over the past 6weeks i have changed the oil twice along with the filter putting back in genuine vauxhall 5w30 oil/gen oil filter on both occasions
    What could be causing this every morning from cold?
    its a 150 1.9cdti if that helps..no warning lights on the dash and drives fine just worried about this rattle in the morning which i assume will be the hydraulic tappets due to lack of oil but how/why???
    Regular Member DeeBe's Avatar
    Jun 2011
    South Shields
    I'd assume it's because the oil takes a moment or two to get round the engine.
    Oct 2009
    LINCOLNSHIRE
    surely though there should be enough sat at the top overnight then when it starts up mores pumped upto the top end?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Dual Mass Flywheel can give a noise similiar to what you are getting. Why did you change the oil twice for?
    Admin plasma's Avatar
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    Likes to be clean and also give it a flush lol?
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Oct 2009
    LINCOLNSHIRE
    Its not duel mass knocking..allways start and stop with the clutch dipped...as said with the low miles i wondered if it was sludged up hence the oil changes to flush any crap out...hasn't worked though so any more ideas.
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    i have a similar thing with mine its done it for 2 years even had the hyd tappets changed still the same just live with it now
    Oct 2009
    LINCOLNSHIRE
    I think your right,only got it untill march anyway then i'm buying the brother in laws zafira design 1.9cdti which by then will have the staggeirng mileage of 15k at the most....that will be my vectra days over but been good and still staying in the fold as to speak.
    Engine : 1.9 CDTi
    All the over 100k ones I have heard have it (Mine does too)
    Jun 2011
    Lincoln
    See the below thread. I have a 1.8 vvti and it does the same thing, noise defo comes from camshaft area.
    http://www.vectra-c.com/forum/showthread.php?t=140387
  1. 1.9CDTI 120 - Rattle on idle (NOT a DMF problem!)
    By snapsnap in forum Engine & Drivetrain
    Last Post: 22nd May 2013, 13:11
  2. VVT rattle at startup. What a damage?
    By mark_l in forum Engine & Drivetrain
    Last Post: 3rd August 2012, 22:27
  3. 1.9cdti 120 conrod rattle
    By Mopar Man in forum Diesel Engine related
    Last Post: 5th January 2012, 01:20
  4. Starting bang/rattle then dies? 1.9cdti
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2010, 12:17
  5. 1.9cdti rattle
    By boz1300 in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2010, 15:37
vectra c rattle on startup
vauxhall vectra 1.9 cdti engine rattle
https:www.vectra-c.comforumshowthread.php142112-1-9CDTi-RATTLE-ON-STARTUP
astra 1.9 rattle on start up
Vauxhall 2 O cdti rattle
2008 vauxhall vectra diesel rattling noise when starting
vectra cdti metalic rattle on start up
vectra c engine cold rattlevectra c rattle noise insignia cdti knock when startingwhats rattling on my vectrainsignia 2000 diesel engine ratle when startingvauxhall insignia cdti rattle on startuprattle vectra b when cold onlymg6 diesel rattle on startupvauxhall vectra 08 cdti noise startupastra 1.9cdti knocking idlevauxhall insignia diesel rattlevauxhall signun 1.9 rattle when startingvauxhall astra 1.9cdti engine noise vectra c sri cdti rattles and hesitates on startupengine rattle vectra b only when coldmetallic clunking sound when starting diesel astravectra has a rattle on startupvectra c clunking noise on startup
